2nd May 2019, 1:06 pm | #1 |
Bang & Olufsen Beocenter 3300 type 1604.
Hi. I have a B&O Beocenter 3300 type 1604, all of a sudden both RH audio output very low tried all combinations speakers wires etc. Any ideas at all?
Many thanks, Steve. |
2nd May 2019, 1:44 pm | #2 |
Re: Bang & Olufsen Beocenter 3300 type 1604.
The wipers inside the sliding controls for treble, bass and balance fall apart in these, if the balance one breaks then this is what can happen. The chassis is fully modular, so you can swap the two power amplifier units over if you suspect that the fault may be in that area, but the sliding controls are the main offenders. You can fuse the wipers back in place into the plastic if that is the cause, it's tricky but not impossible.
3rd May 2019, 8:11 am | #3 |
Thanks for the info I will try and confirm the problem.
Steve. |
