Old 9th Apr 2019, 5:32 pm   #1
6AL5W-Martin
Default Adjusting a Hickok DP200
hello friends,
I am on the search for a calibration + adjust instruction manual or data, informations, to adjust a Hickok Plugin DP 200 (this is a capacitor tester plugin ) in the Hickok Digital System DMS 3200
thank you for any informations.
greetings from germany
Martin
www.wellenkino.de Vintage Scope restorations
6AL5W-Martin is offline
Old 9th Apr 2019, 8:46 pm   #2
factory
Default Re: Adjusting a Hickok DP200
I bought manuals for some of the Plug-ins for the Hickok DMS meter from Manualsplus before they closed down, I will have to add it to my backlog of tasks to photo the relevant bits for you.
Note: The Hickok DMS range was also sold in the UK rebranded by Farnell, I don't know the UK ones were made over here though, as I haven't got one.
factory is offline
Old 14th Apr 2019, 11:04 am   #3
6AL5W-Martin
thank you much for any information.
This DP200 displays in general around - some % from the true Capacitance.
So a 47µF will be tested 44µF , a 34nF is a 33.4nF and so on.
the power supply in the DMS3200 deliver ±20.1V with a ripple of <5mV this may be OK.
I found a 549K 1% what is 560k, will change that.
Old 14th Apr 2019, 9:03 pm   #4
factory
I have tried a free app someone recommended to create some PDF's of the manual.
Here are PDF's of the specifications, calibration procedure, component locations, parts list and the circuit diagram, hope they help.
The calibration procedure requires 100pF-1.111uF & 1-999uF standards (both 0.05%), not sure many people will have those, I certainly don't.
DP200 Specifications.pdf
DP200 Calibration.pdf
DP200 Component Locations.pdf
DP200 Parts List.pdf
DP200 Circuit Diagram.pdf
P.S. Do you want me to scan the operation instructions, circuit description & service procedure?
factory is offline
Old 15th Apr 2019, 7:15 pm   #5
6AL5W-Martin
thank you very much !
I will see to become a useful calibration of that nixie.
This will take a time.
Martin
