Old 16th Jul 2019, 10:49 pm   #1
dave_van_damn
Default Sanyo VTC-5150 chews tape on eject after belt change
Hi all,
Today I spent the whole day cleaning my Sanyo VTC-5150 Beta and replacing the loading belt and idler assembly. After putting it all back together, the machine is now leaving a lot of tape out of the cassette when "stop" is pressed. It seems the problem only really happens when there's a lot of tape on the left reel. This wasn't a problem before I cleaned and replaced the belts/idler.
Any idea what could have happened? Here's a rundown of what I did. Everything was cleaned with Q tips and 100% isopropyl alcohol.
1. Cleaned the tape path thoroughly with including the big circular loading ring thing (you know which one I mean!), the tape posts, the heads and the extremely dirty pinch roller.
2. Removed the cassette caddy
3. Cleaned the part of the tape reels where the idler wheel touches when in use
4. Cleaned the part of the tape reels where the brake meets when in use
5. Changed the loading belt
6. Removed the idler and installed a new one (just the idler itself, not the entire idler assembly plate)
Then I re-installed the cassettle carriage and tested. The machine now rewinds and fast forwards without fail...but seemingly can't wind the tape into the cassette fast enough when "stop" is pressed.
I wonder if it's due to me cleaning the part where the break touches the reel? Or perhaps the loading belt?
This thread suggests doing the torque mod but I didn't have any problem before changing the belts
dave_van_damn is offline
Old 17th Jul 2019, 7:05 pm   #2
dave_van_damn
Default Re: Sanyo VTC-5150 chews tape on eject after belt change
Here's a video to show the problem. Note the tape slack when switching from ff to rw and of course the unspooled tape when "stop" is pressed.
https://drive.google.com/open?id=1g_...KxKSXylSmmN5ON
Old 17th Jul 2019, 7:29 pm   #3
paulsherwin
paulsherwin's Avatar
Do these have a mode switch? This sounds like classic dirty/worn mode switch behaviour.
paulsherwin is online now
Old 17th Jul 2019, 8:08 pm   #4
MickMcmichael
This fault was common on these machines back in the day.
Most likely to be a poor / failing reel motor. It more than likely has a dead spot which won't show on rewind or fast forward.
MickMcmichael is offline
Old 17th Jul 2019, 9:56 pm   #5
dave_van_damn
I just don’t understand how it was fine before I changed the idler and belts...
Old 19th Jul 2019, 3:35 pm   #6
dave_van_damn
Hi everyone,
So far I've identified 2 issues with this player:
1. Excess tape in the machine when unlacing
2. Problems when rewinding/fast forwarding when unlaced
I think issue 1 is due to torque (??)
Issue 2 has me at a loss. It seems when if there's not enough weight on the reel the player cannot rw/ff efficiently and the player locks up. Could this be due to the new idler tyre?
Here's a quick video of the problems-
https://youtu.be/RTGjXION2Qk
I'd greatly appreciate any help people can offer.
Old 19th Jul 2019, 6:53 pm   #7
dj_fivos_sak
Good evening. See this. It should help you.
Fivos
Name:	Screenshot 2019-07-19 at 8.52.33 PM.jpg
dj_fivos_sak is offline
Old 19th Jul 2019, 8:36 pm   #8
dave_van_damn
Fivos
Thank you, I’ll do the mod tomorrow - hope that sorts the ff/rw issue too!
