Old 25th Mar 2019, 6:21 pm   #141
Sinewave
Sinewave's Avatar
Default Re: I hate Steampunk AVOs
I've considered doing that, but only to a Mk5 I have which has an open coil, so the unit is useless/spares anyway.
But I see that as a challenge rather than derogatory to the Avo, as it's one which doesn't work anyway.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 25th Mar 2019, 10:22 pm   #142
The General
The General's Avatar
I like steampunk as a style if it's done well. I saw a steampunk laptop once which was very good - polished wood & brass keys with a cabinet key for the power switch - but some people think sticking a lamp & some gas fittings on a piece of vintage kit does the job. No it doesn't & it's a particularly egregious act if a vintage item is destroyed in the process.
I don't have so much of an issue if an incomplete or damaged item is 'upcycled' in this way, although it could be argued that this removes a potential source of spares from circulation (discuss). A local antique shop has an Avo 7 with a length of conduit & a bulb sticking out the top - it looks awful.
Mark
The General is offline
Old 25th Mar 2019, 10:45 pm   #143
The Philpott
The Philpott's Avatar
As regards the Avometer, it's the perfect storm scenario- aesthetically pleasing (even to drill bandits) rather heavy, made of a material that is an extremely good insulator. Add to this that the visage of the Avo barely changed for decades- which means that the ignorant see something that 'must' be archaic and obsolete, and only good for decoration or re-purposing.
Dave
The Philpott is offline
Old 30th Mar 2019, 7:52 pm   #144
6AL5W-Martin
if I will get a steampunk AVO I will do a fine restoration to become the original instrument.
I hate people who destroy cute old test instruments.
greetings from germany
Martin
www.wellenkino.de Vintage Scope restorations
6AL5W-Martin is offline
Old 30th Mar 2019, 8:53 pm   #145
The Philpott
If money was no object Martin, I would buy many of them and do the same. I did it once and had to ask the steampunker to supply all the bits which he had removed.
We were both polite about it but it was clear that we had opposite views.
Dave
Old 10th Apr 2019, 1:05 pm   #146
electronicskip
electronicskip's Avatar
A couple more examples of steampunk today on Bargain Hunt .
One was a Hanimex 8mm camera on a tripod turned into a lamp and also an older Vacuum cleaner also morphed into a lamp , both with the repro style filament bulbs in you can buy today.
electronicskip is offline
Old 11th Apr 2019, 5:46 pm   #147
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
These 'up cyclers' seem to be lacking in imagination. Almost everything gets morphed into a lamp��
Malcolm G6ANZ is offline
Old 11th Apr 2019, 6:42 pm   #148
6AL5W-Martin
bec. they are to stupid to build another thing then a lamp ..
Old 11th Apr 2019, 8:42 pm   #149
Radio Wrangler
Radio Wrangler's Avatar
Mark
I'm a complete rotter. I'd go in and have a careful look at it. No doubt the shopkeeper would come over and ask if I wanted a closer look...
"A model 7 Avometer, and it's the one with the (made up special feature like Ohms scale in red or not in red).. Those are really quite valuable... pity it's had the innards taken out and a hole drilled in it.... shame.... I've always wanted one for the collection"
Radio Wrangler is online now
Old 11th Apr 2019, 8:43 pm   #150
Paul_RK
Paul_RK's Avatar
I've yet to see an upcycled (dread word) Avo at the local flea market, but there was a Spong mincer-turned-lamp t'other week. I suppose there's no particular shortage of those, though perhaps there are Spong mincer enthusiasts who would groan inwardly at such a sight.
Paul_RK is offline
Old 11th Apr 2019, 11:06 pm   #151
Sinewave
Sinewave's Avatar
I wonder if I can turn an old lamp into a multimeter?
Sinewave is offline
Old 12th Apr 2019, 7:05 am   #152
Radio Wrangler
A bit like the piece of string as a weather station?
If the lamp is dim, the voltage is low
If the lamp is bright, the voltage is high
If the lamp went out with a ping! the voltage is too high
If the lamp is smashed with arcing across the support wires, the voltage is very, very high.
Different voltage bulbs on a range switch?
A battery for the ohms range.
But you need to find a really nice rare and treasured type of lamp to do it to.
Old 15th Apr 2019, 2:01 pm   #153
stuarth
If the bulb is still there, it hasn't really been modified.
How about a "tone-ohm" type circuit instead of the bulb, and test probes instead on a mains plug?
Stuart.
stuarth is offline
Old 19th Apr 2019, 4:14 pm   #154
electronicskip
A reel to reel tape recorder was Steam punked into a Robot/lamp today on money for nothing.
Old 20th Apr 2019, 11:16 am   #155
a robot/lamp.... does it cook or clean the house??
