5th May 2019, 10:56 am | #41 |
Re: Hum in 1950s Truetone Record Player
Does this help?
Miniature 7-pin base The B7G (or "small-button" or "heptal") seven-pin miniature tubes are smaller than Noval, with seven pins arranged at 45-degree spacing in a 9.53 mm (3/8th inch) diameter arc, the "missing" pin position being used to position the tube in its socket (unlike octal, loctal and rimlock sockets). Examples include the 6AQ5/EL90 and 6BE6/EK90. |
5th May 2019, 4:46 pm | #42 |
Thanks again Boater Sam and Livewire. I ordered 7 pin ceramic sockets from an eBay seller yesterday.
5th May 2019, 8:37 pm | #43 | |
These resistance numbers still don't look right. The values I get for the volume pots are correct, 1 meg ohm. The values I get for both valves pins 6 and 7 match what the chart indicates they should be, meter lead to the rectifier diode cathode other lead to valve pin. However the resistance readings for pins 1 through 5 of both valves are all in the 12 to 13 M ohm range, one meter lead clipped to the chassis and the other lead on the valve pins. What am I missing? |
5th May 2019, 8:41 pm | #44 |
Chassis is not B-, measure with reference to B- (HT -ve) There should be no resistance reading between chassis and B-, if there is suspect the isolating capacitor C4 or some other leakage path.
Lawrence. |
5th May 2019, 9:00 pm | #45 |
Thank you for the input but I do not know where the meter lead goes. Can you give me a specific circuit location for the meter lead?
Thank you. |
6th May 2019, 11:05 am | #46 | |
Don't forget when working on your record player with power applied that your record player is a live -ve rail design and that only one side of the mains supply is switched.... ....which means that one side of the mains is connected directly to the HT's -ve rail (B-) when the record player is switched on and that the other side of the mains is connected to that same rail via the valves (tubes) heater circuit when the record player is switched off..... The phono input ground is connected to the chassis, the B- rail is connected to the chassis for signal and safety isolation purposes via the isolating capacitor C4. Lawrence. |
6th May 2019, 12:42 pm | #47 | |
....which means that one side of the mains is connected directly to the HT's -ve rail (B-) when the record player is switched on and that the other side of the mains is connected to that same rail via the valves (tubes) heater circuit, motor and rectifier circuits etc. when the record player is switched off. Lawrence. Last edited by ms660; 6th May 2019 at 12:57 pm. Reason: red text |
6th May 2019, 11:31 pm | #48 |
Thank you for the help. I cut the original plug from the cord and installed a polarized two prong plug. Glad you clarified that for me. Attached is a chart comparing the manufactures original resistance values and my measured values. I'm not knowledgeable enough to comment on it except that it looks like the manufactures values for pin 4 of V1 and V2 are reversed, typo?
Last edited by bennie8; 6th May 2019 at 11:38 pm. Reason: Include resistance table |
7th May 2019, 5:16 am | #49 |
I wouldn't worry about the pin 3 and pin 4 differences, looks like the valve heaters (which are in series), are wired in the other order.
The differences on pin 2 can be explained by the circuit diagram showing 4700 ohm grid resistors and you having 47000 ohm ones fitted. I am a little concerned by pin 1 (cathode). Is R6 (82 Ohm) correct? |
7th May 2019, 3:55 pm | #50 | |
Bernie |
7th May 2019, 4:07 pm | #51 |
What's the colour coding of R6?
82R should be Grey, Red, Black. EDIT. Has the cathode voltage which should be around 4.5VDC ever been measured?
7th May 2019, 8:43 pm | #52 | |
Don't recall that cathode voltage has been read. Is that the heater voltage, valve pins 3 and 4? |
7th May 2019, 9:35 pm | #53 |
Very difficult to tell, but maybe originally it was Grey, Red, Black? Measure the resistance directly across it.
If you're looking at the correct resistor it will be connected to pin 1 of both valveholders. The easiest way to measure the cathode voltage is to connect your meter on volts range across R6.
7th May 2019, 10:22 pm | #54 | |
Thanks again. Bernie |
7th May 2019, 10:36 pm | #55 |
I'd say that R6 has overheated at some point and changed value. I'd replace it.
It probably won't do anything for the hum problem though.
