Old 25th Jun 2019, 11:13 pm   #1
Tyso_Bl
Tyso_Bl's Avatar
Default BC221 frequency meter overhaul.
Picked one of these up at Newbury last Saturday. Looks tidy enough on the outside, the seller did make an effort to clean it up.
Inside is not too bad, except for corrosion to the tuning capacitor and the trimmer capacitors. The crystal switch and band switch shafts have seized where they come through the front panel, the tuning shaft bearings are also notchy, prolly hard grease, looks like damp storage and condensation got to it.
The question is I can't work out how to dismantle the thing (non destructively) in order to get to the bits that need attention. I can;t even work out in what order the thing was assembled.
Has anyone some pointers for me? Otherwise I may try the take out all the screws, and desolder all the wires approach, but that way may lie an unfinished project.
T
Adapt, Improvise, Oh Bother.....
Tyso_Bl is offline
Old 26th Jun 2019, 12:00 am   #2
mickm3for
Default Re: BC221 frequency meter overhaul.
Hi manual here http://www.rkk-museum.ru/documents/a...s/58-44-01.pdf hope this helps from memory 4 screws in front then it slides out of case
mickm3for is offline
Old 26th Jun 2019, 2:04 am   #3
usradcoll1
I always marveled at those instruments when I first started collecting. At present, I have about six of them, all different versions.
Philco had to come out with their own version, using their wonderful Loctal valves.
I incorporated a simple modulator using a Neon lamp. A circuit taken from a surplus conversion manual of the day.
Naturally, I built an AC mains power supply, which everyone seemed to do.
usradcoll1 is offline
Old 26th Jun 2019, 9:54 am   #4
Herald1360
Herald1360's Avatar
I hope it was free or nearly- nice though they are, even good ones don't fetch much
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 26th Jun 2019, 4:11 pm   #5
Brased
Remember that each instrument was individually calibrated - I assume that yours has its proper calibration book in the drop down front panel. Disturbing things may upset the calibration.
Edward
Brased is offline
Old 26th Jun 2019, 8:44 pm   #6
Terry295
Terry295's Avatar
Hi Tyso
I read your post and would like to share an experience of an issue that can affect this equipment. I have one of these instruments and precisely because "looks like damp storage and condensation got to it", the acetate film windows in front of the "thousands" dial and calibration book developed "vinegar syndrome." This is where the film breaks down, shrinks and releases acetic acid. This caused significant corrosion to all metal parts on the front panel and took an age to rectify, this breakdown is accelerated and made worse if it is stored in a warm environment. I hope this hasn't happened to your 221, but it's as well to be aware that it can.
Regards Terry C (ZL4TC)
Terry295 is offline
Old 26th Jun 2019, 9:45 pm   #7
G6Tanuki
G6Tanuki's Avatar
Edward
That's truly the big problem with any ageing-towards-senility frequency-calibration instruments.
Though they may have been useful for a decade or so after original-manufacture-and-calibration, components age and so the original calibration-graphs/books become deeply-untrustworthy.
And you'll find it really hard to find a UKAS-accredited calibration/test facility who knows what a BC221 is, let alone be prepared to take it on to do a proper reference-traceable calibration project.
IMHO better to treat your BC221 as a bit of antique electronica rather than aiming to use it as a day-to-day test-instrument!
G6Tanuki is offline
Old 26th Jun 2019, 10:42 pm   #8
Radio Wrangler
Radio Wrangler's Avatar
The BC221 cal charts were measured and printed automatically, page by page, then the pages were collated into a sort of loose-leaf binding. Incredible manufacturing technology for the day.
Over the years, I did get a couple that were being flung out, to save the drive mechanisms and the capacitor. They make awfully fine drives for VFOs.
Radio Wrangler is offline
Old 27th Jun 2019, 9:15 am   #9
M0FYA Andy
This link gives some information on the original calibration charts -
http://jproc.ca/ve3fab/bc221.html
And this one is to software to make your own -
https://www.royalsignals.org.uk/arti...prog/index.htm
I'm not recommending this software as I've never used it, but it might be of use if you don't have the original charts.
Andy
M0FYA Andy is offline
Old 27th Jun 2019, 8:21 pm   #10
avocollector
I have one of those 221's with the seized front band switch - on the roundtuit pile for now precisely because of that problem so great to see the info here. Given the solidity of the construction I would hate to have been one of the people ordered to destroy it when the enemy were coming!!!
avocollector is offline
Old 1st Jul 2019, 12:15 am   #11
Tyso_Bl
Tyso_Bl's Avatar
Thank you all for the replies, especially the links to the extra info, most interesting. Well the original idea was to get one to canibalise for the tuning gear, I've been aware from other peoples projects that they are rather nice, they are too.
There was a choice of three at the rally, so I bought the last one I walked by, It was a fiver, so I'll get my moneys worth whatever I do with it. Having got it back to the bench I found that the tuning cap is very corroded/rusted, so any calibration will be well off if I do repair it, it would need extensive dismantling to get it out and clean. No real point is there? There are still loads of them about so I plan on getting a better cared for example some day.
Back to plan A.
I think there is the potential to turn this into a nice one or two band self contained QRP CW transceiver, plenty of room in the box so I'm going to have a go. The issue of non destructive disassembly is not too much of a problem now, which was what I was originally worried over.
I hope no-one takes issue with me doing this, but at least I'm not going to table lamp or steampunk it. Had it been in better condition I would have gone with plan B and overhauled/restore it.
The surplus parts will be made use of eventually, the Xtal will live on as a calibration marker.
I did turn an Advance sig genny into a regenerative receiver a while back, works OK and was an interesting project for a few weeks of spare evenings.
T
Tyso_Bl is offline
Old 7th Jul 2019, 11:59 pm   #12
Tyso_Bl
Tyso_Bl's Avatar
Hmm, this may be a lost cause, not had to sort one out this bad before...
Tyso_Bl is offline
Old 14th Jul 2019, 9:07 pm   #13
Tyso_Bl
Tyso_Bl's Avatar
Following on from the previous post, I've managed to get the gearbox mostly disassembled, so the things that are getting me stuck now are:
1, How do I derust the tuning capacitor plates?
2, How do I get the worm gear out of the box housing, I've loosened the set screws, the shaft is a very tight rotational fit in the wormwheel, I don't want to break anything with missaplied force.
3, The worm shaft, the part that the tuning knob is attached to, (it it called a boss), again loosened the set screws, but it won't come off...
help please?
T
Tyso_Bl is offline
