Old 6th Feb 2020, 5:57 pm   #1
onewatt
onewatt's Avatar
Default Possibly Front End HF converter.
Hi all,
Long shot, but does anyone recall this unit? believed to be a hf converter It’s a tidy build, possibly scratch built by a professional looking at the finish, hoping based on a published design. Labelled up as using a couple of 6K7’s.
PW maybe?
Vy Bst
Chris
ID:	198520   Click image for larger version
ID:	198521   Click image for larger version
BVWS, VMARS, RSGB, DEHS, RAOTA
Nothings too big or too heavy, otherwise it wouldn't be where it is!
onewatt is offline
Old 6th Feb 2020, 6:45 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Possibly Frontend Hf converter
Yes, though it's built using an interesting range of parts.
The main tuning-capacitor, tuning-drive and coil-pack look to be from the 1930s - Octal valves from the same timescale.
I'm thinking that it could have been designed to take something like a 6K7 as the RF amp, and either a 6A8 pentagrid converter, or the 6K8 triode-hexode.
G6Tanuki is offline
Old 6th Feb 2020, 7:45 pm   #3
turretslug
turretslug's Avatar
Intriguing device- my initial thoughts were HF converter but I then thought that what would be noticeably different looking LF-wards oscillator coils all look similar to the others- HF osc coils would always look similar, but LF ones running at different frequency ratios would surely have different-looking windings, especially on the lowest band. Also, no obvious sign of padders, though it's difficult to be sure, or some form of output tuning. (Though there's possibly a mica capacitor at bottom right against the chassis rear apron, though only one visible). Again, all circumstantial. Maybe it's a "tight" preselector, of low-volume production. Post-war, Racal produced a large 19" preselector to give the RA17 a better chance in the ship-board environment with triple-tuning and 2x low-gain ECC82 cascode stages- maybe this is an earlier example of a similar beast?
Surely tempting to put it into action again- the thoroughness even looks to extend to aerial trimming.
turretslug is offline
Old 6th Feb 2020, 9:05 pm   #4
onewatt
onewatt's Avatar
Default Re: Possibly Front End HF converter.
Thanks, appreciate the comments.
Yes, I’ll get some power on it, haven’t studied wiring and not sure of valves yet but the screening partitions both have 6K7 pencilled on them.
Working away so can’t take anymore pics until I’m home.
But will upload some close ups as soon as get the opportunity.
ATB
Chris
onewatt is offline
Old 6th Feb 2020, 9:38 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
With the organisation of the coil pack, I wonder how they adjusted slugs to get the stages aligned across each band?
Radio Wrangler is online now
Old 6th Feb 2020, 9:51 pm   #6
turretslug
turretslug's Avatar
I wondered that, too- perhaps they were air-cored without slugs and were made precisely enough to be close without adjusters, as in the BC348? The formers look rather similar to the baked paper roll types in the CR100, with the same arrangement of a small brass bar running through slots and having a tapped hole in the middle for securing.
Talking of CR100s, the tubular capacitors with pitch-seal ends, radial leads and green labels are like the Muirhead ones I found in an early CR100, they were the most dramatically leaky that I've ever come across!
Old 6th Feb 2020, 10:06 pm   #7
G6Tanuki
G6Tanuki's Avatar
I suspect it would have been tricky.
Others have noticed the apparent absence of padders - but I'm wondering if it could have been designed to front-end an existing receiver, as a preamp for the MW/LW bands and a converter for the amateur HF bands? If it was downconverting to - let's say 1.6MHz - then the difference between the LO and RF frequencies is sufficiently small that, for a small frequency-spread [as would be suggested by the low number of fixed/static vanes on the tuning capacitors] you don't really need to bother with padders. It's seemingly got a separate antenna-trimmer too, which would easily tune out any alignment errors over a half-MHz or so.
One thing that puzzles me - the front-panel knob on the bottom left appears to drive a rod that runs through the coil-packs to a switch on the rear of the chassis - perhaps this is some sort of 'straight-through' switch to feed the antenna direct to the 'back-end' receiver ?
G6Tanuki is offline
Old 6th Feb 2020, 10:10 pm   #8
ms660
ms660's Avatar
I don't think they are any slugs in those type of coils.
All wave pre-selector ?
Lawrence.
ms660 is offline
Old 6th Feb 2020, 10:20 pm   #9
turretslug
turretslug's Avatar
The apparent simple logging scale would be more appropriate to a preselector, too- select band, tune for peaked noise without necessarily needing precise frequency display. Whereas a logging scale-only converter would be a bit clunky to use. Granted, the HRO does things that way, but with a highly resolving logging arrangement.
Old 6th Feb 2020, 10:32 pm   #10
M0FYA Andy
They look like Wearite coils?
Andy
M0FYA Andy is offline
Old 6th Feb 2020, 11:17 pm   #11
G3VKM_Roger
G3VKM_Roger's Avatar
Andy
Yes, they do and usually there is a type number painted on. There's a thread here on Wearite "P" series coil sets.
https://www.vintage-radio.net/forum/...ad.php?t=64856
Roger
G3VKM_Roger is offline
Old 7th Feb 2020, 8:33 am   #12
Radio Wrangler
I too think it's a preselector, intended to improve a separate receiver.
The similarity of the coils in each stage fits this. The valves would have been high impedance buffers between the resonator stages to make the bandwidth narrow.
In the days of single-conversion low IF receivers, image rejection on the HF bands was very little, and the 40m band had megawatts of broadcasters next door. A preselector was a useful tool.
