Old 25th Oct 2007, 10:56 pm   #1
Skywave
Question 10 MHz sinewave osc. - your design suggestions
I have a need for a 10MHz sinewave oscillator. It needs to produce about 350mV rms into 75 ohms, very low distortion and very frequency stable. DC supply can be anything between +5v and +15v.
Armed with this as a starting point, I acquired a 10MHz "osc.-on-a-chip" device (Epson) that produces a TTL output. (I was surprised how cheap it was!) My first attempts were to route the chip's O/P through an L/C cct. tuned to 10MHz and then to an emitter-follower. Unfortunately, this failed, since the input Z of the EF seems to excessively loads the tuned-cct. A junction FET (higher input Z) didn't help, either.
Oh - and I should add - just to avoid any confusion - that this must be a 'solid-state' affair; 'fraid valves are definitely out of it for this job!
Any comments on a design approach would be welcome.
Thank you.
Al / Skywave.
Skywave is offline
Old 26th Oct 2007, 8:14 am   #2
ppppenguin
ppppenguin's Avatar
Default Re: 10 MHz sinewave osc. - your design suggestions
An emitter follower loaded with 75R will have quite a low input impedance. I would suggest a low pass filter (simple 5 pole butterworth is probably fine in this context) rather than tuned LC. The EF will then probably be OK. Put a 100R resistor in series with the base as a stopper.
Any video opamp will deliver 10MHz into 75R. Old fashioned parts like EL2020 or modern ones like AD8051 are all OK. Typically in video applications the output has a series 75R resistor so that the opamp has to produce twice the voltage requied by the load.
Whether you are using EF or opamp beware of capacitative loads which can cause oscillation. A series termination on the output is a complete cure.
There shoul dbe loads of application notes on the Analog Devices and Maxim websites.
ppppenguin is offline
Old 26th Oct 2007, 4:26 pm   #3
Skywave
Thumbs up Re: 10 MHz sinewave osc. - your design suggestions
Thanks Jeff - I hadn't thought of this in the context of 'video'; I was thinking exclusively in 'RF-mode'
On reflection, I can see that the LPF approach makes more sense - thanks for the 'steer'.
I've had to shelve this for a bit - a few other issues have arrived today which are more pressing. I'll come back here with a report at a later date.
Al / Skywave
Skywave is offline
Old 27th Oct 2007, 5:49 pm   #4
Phil G4SPZ
Phil G4SPZ's Avatar
Al,
Would a 10MHz crystal oscillator be stable enough for your purposes? There should be several suitable circuits in Solid State Design.
Phil
Phil
Phil G4SPZ is offline
Old 27th Oct 2007, 9:05 pm   #5
Skywave
Arrow Re: 10 MHz sinewave osc. - your design suggestions
Hi Phil -
Presumably, you are referring to "Solid State Design For The Radio Amateur" by ARRL. If so, yes - tried that source. Page 19 shows a bi-polar and a FET design: both of which gave a considerably distorted waveform.
A bit of background -
I need to be able to lock a frequency synthesizer from an external source (which must be 10.000 MHz) and experiments to date indicate that the external freq. source must be extremely accurate, pure & stable if lock is to be achieved. A level of about +3 dBm is ultimately required (this bit should be relatively easy )
Aside.
'Solid-state' crystal oscillators - as a 'building block' - have always given me a hard time! Usually, no O/P at all is the result Free-running oscillators, mixers, amplifiers, etc. - no trouble (almost) at all; crystal oscs.: )
That's why I went for the 'osc. on a chip' approach - and at the price - very competitive.
However - thanks for the 'steer'.
Al / Skywave.
Skywave is offline
Old 27th Oct 2007, 9:35 pm   #6
evingar
evingar's Avatar
I'd concur with that. I've used a small SM oscillator with some nixie clocks I've designed (CPLD based). The oscillator gave me more hassle than any other aspect of the design (inaccuracy, failure to startup from cold etc). Layout seemed very critical and I strongly suspect they were susceptible to external noise !
I ended up using a small Epson SM device - cost about £2.00 from Farnell ISTR
Chris
evingar is offline
Old 28th Oct 2007, 9:05 pm   #7
Phil G4SPZ
Phil G4SPZ's Avatar
Hi Phil -
Yes, Al, the ARRL book is a good source and I have home brewed a couple of simple xtal oscillators many years ago. My 80 metre QRP rig, George Dobbs's "SCD", also worked very well with its simple VXO. I didn't have many problems getting my crystal oscillators to work, but I certainly wasn't looking for the purity of output that you seek, nor do I have the test equipment to measure it!
Good luck, and no doubt you'll share the ultimate solution with us all. Regards,
Phil
Phil
Old 29th Oct 2007, 12:31 am   #8
Skywave
Yes, yes - that sounds exactly like what I am currently using!
Al / Skywave.
Skywave is offline
Old 29th Oct 2007, 8:15 pm   #9
Dickie
Could you expand on why it needs to be a very pure 10MHz? The frequency synthesizers I am acquainted with are generally constructed with digital dividers and phase detectors and they work best with a square wave. I ask because I have a number of 10MHz xtal reference oscillators looking for a good use but they produce a TTL output.
Regards,
Richard, BVWS member
Dickie is offline
Old 30th Oct 2007, 12:18 am   #10
Skywave
OK.
I used the term "freq. synthesizer" rather loosely, since the application isn't that relevant; I was simply trying to give a broad, general picture of the intended use for the sake of completeness.
But since you ask, this is a task arising from my employment. There are a number of pcb assemblies that I frequently encounter that incorporate a discrete, custom PLL design, tuning 88 - 108 MHz as the 'tuning heart' of a low-power FM exciter. This cct. has the facility to lock to an external source rather than its own embedded TCXO. To test the functionality of this external port, I usually use an HP 8640B - but there are occasions when this SG is tied up doing something else. The design of the PLL cct. requires the external signal type and spec. as I have stated: the design of the PLL cct. etc. is not under my control; evaluating its functionality is, however.
Extensive testing with the 8640B - and using other signal sources - has determined the nature of the I/P signal required; i.e. the accuracy, stability, distortion & level that is required to achieve lock.
Al / Skywave.
Skywave is offline
Old 30th Oct 2007, 8:23 pm   #11
Dickie
Hmmm, you haven't got much room for manouvre there. Trying to emulate an 8640B is not easy! I agree with all the eminent posters before me that you have to start with a crystal oscillator simply to get the low noise and stability you need. Follow that with an op-amp to get down to 75R and then a LPF to get rid of all the harmonics.
An alternative to the op-amp - assuming the oscillator has a TTL or CMOS output, you could feed it into 3 or 4 TTL buffers (e.g. 74LS06) in parallel which would then drive 75R (honest- I've seen it done)
Regards,
Dickie is offline
Old 9th Nov 2007, 12:29 am   #12
Skywave
Task now successfully completed.
I used the CMOS / TTL 10 MHz 'osc.-on-a-chip' - as referred to earlier - followed it with a 3-section Butterworth LPF and a simple attenuator to get the level down to +3dBm / 75-ohms. No additional amplification was necessary, since the O/P from the osc. is 5v. peak, producing ample O/P from the LPF.
Hooked it up to the Item Under Test - bingo! It locks the PLL.
Now where did I put that second-hand die-cast box to house this unit ?
Al / Skywave.
Skywave is offline
