17th Mar 2023, 8:42 pm | #1 |
Resistor for a TMK 500TU-B
My dear friends,
I have a TMK 500TU-B multimeter. One resistor is burnt, is a 34 Ohm resistor. As you can see it has been changed in the past but I can not "read" the colours, and probably is burnt because it was the wrong resistor. What kind of modern ones do you recommend? I think that the tolerance is 1%. There is a lot of info here about the TMK 500 multimeter but nothing about the 500TU-B one. Diagrams are very different! Thank you in advance!! |
17th Mar 2023, 9:03 pm | #2 |
Re: Resistor for a TMK 500TU-B
The value is written on the board on these is that not still readable?
Have you seen this video? https://www.youtube.com/watch?v=Cn8-fxWBcAo Cheers Mike T
17th Mar 2023, 9:10 pm | #3 |
This is the taut band version;
See #31 ; https://vintage-radio.net/forum/showthread.php?p=934350 You could use a 0.5W metal film resistor - 33 ohm in series with 1 ohm
Home, home again - I like to be here when I can |
18th Mar 2023, 10:05 am | #4 | |
18th Mar 2023, 10:08 am | #5 | |
So 500TU has the same diagram as 500TU-B I will keep that diagram then. |
21st Mar 2023, 7:40 pm | #6 |
Some of the end caps of those green resistors seem to be touching.
The insulation (paint) may break down at high voltages. |
