15th Mar 2023, 1:23 pm | #1 |
Rank arena 2000GT with a Lenco B55
Sound is coming from only one channel (cleanly, other is crackly) when using the built in amplifier and when attempting to bypass it to a separate amp, I then end up with buzzing.
I have tried contact cleaner on the dials and the cartridge to no avail. Any advice is appreciated. Last edited by ChrisChilton; 15th Mar 2023 at 1:24 pm. Reason: Missed a sentence |
19th Mar 2023, 10:26 am | #2 |
Re: Rank arena 2000GT with a Lenco B55
Hi. I serviced a few of these years back, the version I saw mostly the RTA-2000. They all suffered with drying out of the small electrolytic caps in the tone network. The caps in question all have a tiny 'sun' logo on them. This was 1980 when they were failing, so what values they've gone to now I can only guess. Replacing these will have a dramatic effect on the sound quality.
These are excellent units, and with the original speakers still sound good, with plenty of range on the tone controls. Nice punchy bass response. These are well worth any time any spent on them. Plus you've got minimalist Scandinavian styling as well!
It's never been right since we've had it... |
12th Apr 2023, 12:21 am | #3 | |
12th Apr 2023, 8:06 am | #4 |
Does this only crackle on the gram (phono)?
12th Apr 2023, 12:18 pm | #5 |
The right channel is weak no matter which output you use, phono or radio, built in amp or external amp.
The humming has been partially rectified by moving the powerlead as far away as possible from the din-to-rca that’s going to the external amp. |
12th Apr 2023, 1:15 pm | #6 |
It could be just that the input selector contacts need cleaning. If not, then the DC power rail to that channel may be down. .
Edward. |
12th Apr 2023, 3:18 pm | #7 |
Not long ago I overhauled an RTA2000.
Every single small electrolytic capacitor will need to be replaced. They were all either open circuit or wildly off value. It sounded excellent once it was working correctly. Well worth fixing! Jan |
12th Apr 2023, 5:03 pm | #8 | |
Thanks for the advice, any idea on how much that would cost as I fear it’s beyond my expertise. |
12th Apr 2023, 5:19 pm | #9 |
An unknown repairer can be very expensive or even a ripoff. Post on h5re for genuine support under "Services Needed" .
Edward. |
12th Apr 2023, 6:12 pm | #10 |
12th Apr 2023, 8:04 pm | #11 |
It's almost impossible to give you a Ballpark figure. It's a bit like you taking your car to a garage and asking them to give you a price for fixing it. If you push me, I would say between 50 and 75 pounds from a Member here. If it's an unknown 3rd party - expect more......
Edward. |
12th Apr 2023, 11:04 pm | #12 | |
I found a 7” copy of Anarchy in the UK for 50p today, that’s going to get sold towards the repair costs. |
