5th Mar 2023, 1:58 am | #1 |
Model 48A Battery
Good evening again.
A simple question : I have a model 48A meter that I would like to test. I know that it takes one battery of 1.5v and I have some AA battery holders that I can use, so can anyone tell me the polarity. I don't want to start by taking the unit apart and the battery compartment has no markings. I have taken a photo, so which is the +, A or B please. I just want to see if the resistance range works, I know the DC range works on batteries. Regards ..... Gary |
5th Mar 2023, 3:27 am | #2 |
Re: Model 48A Battery
Hi batt type r1662 Eveready so B is + scans of battery case are online if you wanted to make a lookalike , Lots of info at Richards Radios website http://www.richardsradios.co.uk/avometersdata.html Mick
5th Mar 2023, 1:43 pm | #3 |
Thanks Mick,
I was on that site last night and thought I had it worked out. Just wanted another opinion I suppose I'll have another look at the 48A later, first I need to take my wife to a garden centre before any more AVO's turn up Regards ..... Gary |
6th Mar 2023, 4:46 pm | #4 |
If you connect a 1.5V cell at random with a series 10k resistor and short the leads together on ohms, watch which way the needle moves. You've a 50% chance of getting it right and if you don't, no harm will result!
15th Mar 2023, 12:28 am | #5 |
Well I know the polarity now, thanks gents.
Will fit a C size battery holder instead of an AA holder. Regards ..... Gary |
17th Mar 2023, 8:57 am | #6 |
I would have thought a modern Alkaline AA cell would have an internal resistance at least as good as the original cells, and AA cells are much more readily available, and cheaper, than C cells.
Stuart |
25th Jun 2023, 9:28 pm | #7 |
One of my Avos arrived with an (exhausted) R1662 battery inside it. I found that a C-cell fits into the empty R1662 case perfectly.
The extra capacity of a C cell compared with an AA cell might make sense if you intend using the low-ohms range a lot - the 34-range Avometer delivers around 100mA from the test prods on the lowest resistance range.
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 25th Jun 2023 at 9:29 pm. Reason: Clarity |
