2nd Mar 2023, 12:26 pm | #1 |
Mystery Philips device
Anyone know what this Philips item is?
2nd Mar 2023, 12:36 pm | #2 |
Re: Mystery Philips device
2nd Mar 2023, 1:23 pm | #3 |
Here's a link to a Philips book showing the 2764 amplifier and some other amplifiers in that series plus other stuff:
https://nfor.nl/radioforumservice/pd...boek-radio.pdf Lawrence. |
2nd Mar 2023, 1:46 pm | #4 |
Up to 20 high impedance speakers in parallel... Railway station or factory PA?
2nd Mar 2023, 10:58 pm | #5 |
Fascinating! Many thanks Lawrence.
3rd Mar 2023, 2:27 am | #6 |
Maybe my translation is defective, but it sounds like, not the standard 100V line speaker network, but 1000V line. Seems excessive, raising electrical safety issues. Did it ever happen?
Martin
BVWS Member |
3rd Mar 2023, 6:59 pm | #7 |
It is mentioned that 1000V is present as the anode supply voltage of the MC1/50 output stage and that it's interrupted when you open the case. It likely uses an output transformer.
5th Mar 2023, 4:07 am | #8 |
Any chance someone has a schematic?
I found it listed for sale on Facebook marketplace. A friend went to pick it up as it's a long way from me. He says it's huge and very heavy. He needed assistance from a second person to lift it. |
5th Mar 2023, 7:16 am | #9 |
Now that we've retrieved the item from the seller, here are a few photos.
5th Mar 2023, 9:19 am | #10 |
Looking at the pictures of the innards, it seems clear to me that most of the amplifier has been modified/changed in later times. Just compare the pictures with "figuur 2" in the user manual (linked to in post #2).
My impression is that the original single ended output configuration was changed into push-pull. The small signal valves look like they have Octal bases (while the original small signal valves did not have Octal bases). The connector in the right corners also looks Octal. The "Fergusons Radio" output transformer, made in Australia, is also 'unnatural' for a Philips product.
Robert |
5th Mar 2023, 10:35 am | #11 |
A lovely bit of kit. Looks like it was plugged into a lamp holder. Cheers, Pete.
9th Mar 2023, 12:15 am | #12 | |
