Old 1st Apr 2019, 11:47 am   #1
Steve G4WCS
Steve G4WCS's Avatar
Default Zinc plate and passivate? Restoration.
Picked up a "linear" amplifier.
Front panel looks OK and it needs a good de-dusting. but the back panel could do with a light restoration.
Is it zinc plated and passivated and is there a receommended method of restoration? I'm thinking alng the lines of some sort of coloured lacquer ( I'm sure you could get something similar for restoring the finish on carburettors ) rather than completely dismantling the unit and getting the panel re-plated.
ID:	180692   Click image for larger version
Steve G4WCS is offline
Old 1st Apr 2019, 5:07 pm   #2
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Zinc plate and passivate? Restoration.
I'm not sure that I've heard of a passivation process being applied to a zinc coating. Perhaps more likely, the platers had some tricks up their sleeve to get a zinc plating with a specific look.
Most carburettors are made of aluminium alloys; I don't think I've seen one with zinc plating.
There are kits on the market to carry out plating by means of a cotton swab on the end of a graphite rod, that is dipped in a plating solution and then used to do electroplating. I've seen quite good results from them, especially when the area is small as in your case. They may well be worth a try.
B
Bazz4CQJ is offline
Old 1st Apr 2019, 7:58 pm   #3
Steve G4WCS
This was the stuff I was thinking of. Supposed to replicate zinc chromate
https://www.frost.co.uk/eastwood-bro...SABEgJfvPD_BwE
Old 1st Apr 2019, 8:57 pm   #4
Bazz4CQJ
Bazz4CQJ's Avatar
So, the Eastwood stuff is an acrylic paint which looks like zinc chromate. I wonder how closely it will match?
If you are going to remove the existing zinc with carbide paper or whatever, I guess that will get you down to to plain steel. As you don't have endure the under-bonnet conditions of temperature and petrol, I wonder if you could find something cheaper than £16, perhaps something from the model paint people like Humbrol (who have a metallic bronze).
I'm not too sure that any paint will give a really close match to real zinc plate, but guess it depends on how demanding you are .
B
Bazz4CQJ is offline
Old 1st Apr 2019, 11:40 pm   #5
alanworland
alanworland's Avatar
Unless things have changed I thought a zinc plated finish could either have a clear or coloured passivated finish applied?
Might be worth asking a platers
Alan
alanworland is offline
Old 2nd Apr 2019, 3:26 am   #6
Bazz4CQJ
Bazz4CQJ's Avatar
Might be worth asking a platers. Alan
A couple of moments on Google reveals that zinc platers do indeed use the term "passivation" to describe the addition of a chromate layer on top of the zinc layer.
The terminology is a bit loose; a more formal description of passivation is as per Wiki https://en.wikipedia.org/wiki/Passivation_(chemistry) but we start to get in to splitting hairs over passivation and inhibition.
For an object which lives in a environment which is not very corrosive, I think you'd expect standard zinc coating to be satisfactory.
B
Bazz4CQJ is offline
Old 4th Apr 2019, 8:47 pm   #7
Steve G4WCS
Linear arrived tonight. Opted for citric acit derust (lemon juice), Brasso, and hard paste wax.
Will do a restoration post in success stories if 80’s kit is deemed vintage / interesting enough
ID:	180888   Click image for larger version
ID:	180889   Click image for larger version
ID:	180890   Click image for larger version
ID:	180891   Click image for larger version
Old 4th Apr 2019, 11:05 pm   #8
Bazz4CQJ
Bazz4CQJ's Avatar
That looks really good. A re-visit with the wax every blue-moon might well keep it that way!
B
Bazz4CQJ is offline
Old 6th Apr 2019, 8:21 pm   #9
Uncle Bulgaria
Uncle Bulgaria's Avatar
That's made a real difference - it's easy to see where the tissues were (I assume soaked in lemon juice?)
Uncle Bulgaria is offline
Old 6th Apr 2019, 8:42 pm   #10
Steve G4WCS
Yes, an hour in lemon juice, brought the rust pits back to grey steel
Old 7th Apr 2019, 12:28 am   #11
Bazz4CQJ
Bazz4CQJ's Avatar
And by "lemon juice" we really mean...citric acid, as I mention... occasionally
B
Bazz4CQJ is offline
Old 24th Apr 2019, 7:01 pm   #12
Uncle Bulgaria
My mother had great difficulty getting citric acid a few years ago for some preserves. The shopkeeper said that apparently there was some control of it because of its propensity to get cut with cocaine!
Old 24th Apr 2019, 8:00 pm   #13
Bazz4CQJ
Bazz4CQJ's Avatar
Never had any problems, either on the High Street or ebay.
Used some citric yesterday to clean up a small mild steel bracket which was rusty in some places and covered with zinc plate in others. Cooked it up to about 50°C, and after about an hour, both the rust and the zinc were gone leaving a very a really nice surface to paint with primer.
B
Bazz4CQJ is offline
Old 24th Apr 2019, 8:40 pm   #14
superdirto
That's a good Linear I have one of those, very clean output and the preamps a boon
Blue lateral's gone ..............nope..........
.......you had it then.................way out!
superdirto is offline
