Old 22nd Jul 2019, 3:01 pm   #1
Chris Manville
Default Dictograph Wiring
Hi all
So I thought it would be fun to set up a little coms system between the garage, garden etc and have managed to get hold of 3 dictograph units. All identical
Can't see a model number but does have a date of 1974 inside
Am I right in thinking they work on a 6vdc supply?
Also, not a clue on how to wire, which is the supply feed etc etc
Any help much appreciated
Chris Manville is offline
Old 22nd Jul 2019, 7:52 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Dictograph Wiring
Posts #5 & #8
HERE may help you.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 22nd Jul 2019, 10:12 pm   #3
Dave Moll
Dave Moll's Avatar
Thanks, Graham, for that link. I have mislaid the piece of paper I scanned for post no. 5!
Dave Moll is offline
Old 28th Jul 2019, 8:54 am   #4
Dave Moll
Dave Moll's Avatar
If the original poster should check back (last activity some three hours after the initial post), I wonder what progress has been made.
In case it is of any help to him or any other Dictograph experimenters, I attach below a document setting out how I have wired my setup (in a way that avoids having units permanently wired together).
Also attached is a picture of the interconnection box, which also contains a 6V power supply (4x "C" cells). Although only four connectors have been installed, up to seven are supported.
Name:	Dictograph interconnection box.jpg
