9th Apr 2011, 11:22 pm | #1 |
H aerial
Hi, I think this should go here. Anyway, I would like to make a H aerial but does anyone know what type of metal I should use for the Dipole and the reflector?
9th Apr 2011, 11:35 pm | #2 |
Re: H aerial
Within reason, anything will do. Light gauge aluminium tubing about 10mm or 3/8" OD would do nicely and be similar to the original (if it's a band 1 TV type you're considering).
9th Apr 2011, 11:50 pm | #3 |
Re: H aerial
ok, thanks for that! Yes, I am building it for that use (really, I just want to have a go at making my own!)
10th Apr 2011, 12:44 am | #4 |
Re: H aerial
Band I aerials here are generally made of aluminium tube about 10mm diameter as Herald has suggested. The last one I looked at here had a dowel inside the tube, presumably for a bit of physical strength in strong winds etc.
10th Apr 2011, 12:25 pm | #5 |
Re: H aerial
I'm not sure of exact details but seem to recall reading that some aerials had string inserted inside the rods to damp down wind vibration.
10th Apr 2011, 10:52 pm | #6 |
Re: H aerial
11th Apr 2011, 11:17 am | #7 |
Re: H aerial
I'm not sure how critical this will be, but don't forget that the length for resonance depends to a small extent on diameter, so if you are following a design then thinner elements need to be slightly longer.
