Reply
Old 26th Apr 2010, 5:26 pm   #321
0108vesa
Default Re: The "Sussex" Homebrew Valve Tester.
Hi!
This is my case, some recycled device. PCB is ready made and all 5 transformers are connected. Just waiting for solution for diode / rectifier testing. Frank.C gave us excellent solution for that but with my modest skills I can't calculate, what are correct values for components...
Vesa
0108vesa is offline   Reply With Quote
Old 26th Apr 2010, 11:31 pm   #322
FRANK.C
FRANK.C's Avatar
Hi Vesa
You have a nice job done on the cabinet
I am progressing rather slowly with the Sussex.
I've done a little trial and error with the resistors and there values are working out at something like
5mA 100R
15mA 33R
30mA 16R
60mA 8R
120mA 4R
180mA 2.8R
It would have been easier if I just did the math's
I don't think a 1mA range is necessary. The above test were done with a low HT of just 15V as I haven't got that side of it working yet.
It will be sometime before I get mine finished.
Frank
FRANK.C is online now   Reply With Quote
Old 26th Apr 2010, 11:39 pm   #323
Guitarist28
Guitarist28's Avatar
Hi Vesa,
Congratulations on your case it looks good.
Regards
Rob
Guitarist28 is offline   Reply With Quote
Old 29th Apr 2010, 6:10 pm   #324
thor1961
Here is a image of the tester based on a Hammond #1456 series enclosure, its crude at best but represents a basic layout ect... Tester Image.jpg
Name:	Tester Image.jpg
thor1961 is offline   Reply With Quote
Old 29th Apr 2010, 6:16 pm   #325
lioc-2413.
Hi Mike Brian here OAP. I saw you valve tester in the bulletin and just had to have go.
I have a question what values are the two ZDs 11&12 can't see the value but it could be my age. I see from forum you`re on to a winner good one
Many thanks Brian Smith
Last edited by Brian R Pateman; 29th Apr 2010 at 6:21 pm. Reason: E-mail address deleted - please use PM for communication.
lioc-2413. is offline   Reply With Quote
Old 29th Apr 2010, 6:16 pm   #326
Guitarist28
Hi Thor,
Your initial image looks good. I've had a look for a Hammond #1456 case here in the UK and I must admit (unless anyone corrects me here) I can't seem to find any for sale.
Regards
Rob
Old 29th Apr 2010, 6:20 pm   #327
swordholder
Hi Thor & Rob
Thor, what a superb job, that cabinet is ideal.
Rob, this is what I had in mind, make the ends,base * back from MDF and bend the ali to the shape in the Hammond box.
Mike
swordholder is offline   Reply With Quote
Old 29th Apr 2010, 6:29 pm   #328
thor1961
Rob here is a link for Farnell UK > http://uk.farnell.com/hammond/1456pk...%231456PK4BKBU Mikes idea would be probably a better way to go, but the basic dimensions can serve as a guide ect...
Old 2nd May 2010, 1:12 pm   #329
duderduderini
Default The "Sussex" Homebrew Valve Tester.
Greetings from DIY Audio.
This looks great. Sorry to jump in at page 17 but I believe boards might still be available?
Could Swordholder let me know if this is the case.. for private use only.
Is there a list of components needed? Australia is 240 Volts mains so I guess iron is the first thing
Many thanks and congrats on a great job
Nick
duderduderini is offline   Reply With Quote
Old 2nd May 2010, 1:33 pm   #330
thor1961
Has there been any revisions or modification done to the pcb to facilitate for updates like Eds transformer, the gas test and a fan ect... If so could someone post a layout either pdf or jpg and are they available for purchase ? Thanks
Old 2nd May 2010, 4:23 pm   #331
swordholder
Hi Thor.
If you look through thr posts from the beginning, there are all the details you want, includung PCBs from Martin.
If you dont understand anything, please ask.
Regards
Mike
Old 2nd May 2010, 4:28 pm   #332
swordholder
Nick,
Yes as far as I know PCBs and transformer are available from Martin and Ed respectively, see previous posts (I know there are a lot to look through) but there is a great deal of information there.
The Valvetester is freely available for personal use only please, I wouldn't like it very much if commercial use was made of my design work.
Regards
Mike
Old 2nd May 2010, 5:20 pm   #333
thor1961
Swordholder, Please understand I have no commercial intention's for your extremely wonderful design ! Having looked at building a tester for over 2 yrs now, and the cost being close to $300.00 USD I simply want to construct it to the best of my ability. I had ordered a transformer from Ed which should arrive any day now, but choose to wait on the pcb till all/or if any revisions or modification's had been made. For what its worth I had probably looked at 50 plus diy based testers ! Thank-you for sharing this truly amazing design ! Thor
Old 2nd May 2010, 7:37 pm   #334
M0XNA Neil
I have constructed and tested the chassis for my 'Sussex in a Suitcase' and have attached some pictures of my bench test set-up. Readings for an ECC83 are:
Va= 250V
Vg= -2.0V
Ia= 1.8mA
Gm= 2.0mA/V
Neil.
ID:	35279   Click image for larger version
ID:	35280   Click image for larger version
An engineer makes for a penny what a scientist makes for a pound!
M0XNA Neil is offline   Reply With Quote
Old 2nd May 2010, 8:08 pm   #335
Guitarist28
Hi Neil,
Looks very good and functional - I bet that you are pleased with it. I wonder if you are the first to have an operational unit?
Regards
Rob
Old 2nd May 2010, 8:44 pm   #336
swordholder
Neil,
Congratulations on building the Tester. I'm very pleased someone else has finished one, as you can imagine, although mine worked perfectly, it's nice for a second person to build one and confirm that mine wasn't a fluke.
Well done
Mike
Old 2nd May 2010, 8:54 pm   #337
M0XNA Neil
Thanks Rob and Mike,
Because I used major components from around my garage to build it I had to make some changes to accommodate my higher HT from the transformer I found lying around. However, the HT regulation is your original design. I have built mine with separate DVMs in the lid of the suitcase so I can have four of them to also set cathode currents on the valve guitar amps I also build as a hobby.
Neil.
Old 3rd May 2010, 1:10 pm   #338
duderduderini
Default How do I get in touch with
Hi Thor
I cant find a place to pm martyn and ed.. there doesnt seem to be a pm function. I guess that being a noob here that i may not have pm priveliges
but i would like to get the boards and transformer
Thanks for your help and I promise to read the posts and of course it is for private use only....
Regards
Nick
Old 3rd May 2010, 1:16 pm   #339
Brian R Pateman
Brian R Pateman's Avatar
Nick,
Now that you have a post approved you should be able to use the PM system (you will need to wait for the software to catch up with your post count).
Click on the user name and select "Send a private message to....".
Brian
Brian R Pateman is offline   Reply With Quote
Old 3rd May 2010, 7:46 pm   #340
Andymic
For those who've come in late.
The BOM is here http://spreadsheets.google.com/ccc?k...pfMlE&hl=en_GB
Good luck!!
Andymic is offline   Reply With Quote
Reply
