16th Jan 2020, 9:37 pm | #21 |
Re: What exactly is meant by a 'Transcription' Turntable?
Hi. I think this is the thread Dave W means :- https://www.vintage-radio.net/forum/...d.php?t=126186
David. Last edited by teetoon; 16th Jan 2020 at 9:43 pm. |
16th Jan 2020, 9:55 pm | #22 |
Yes that's it David-many thanks! Now everyone can see the deck in "question" plus Clive's great restoration What "does the team think?" Could it be one of the missing 201's produced fro BH?
Dave |
16th Jan 2020, 10:47 pm | #23 |
Could Gordon Russel have had anything to do with the cabinet styling. I know that he was responsible for some Murphy's, including one I have awaiting repair, an example of which is or was in the Gordon Russel Museum in Broadway, Worcestershire.
17th Jan 2020, 1:16 am | #24 |
That may well be the "case" Live Wire. I never seem to get enough time researching 30's Design and Art but here in the South, the De La Warr Pavillion is the perfect background. It's fascinating tracing out those involved in that modernistic movement of the time with Architecture, Radios and everything else.
Dave W Bexhill |
17th Jan 2020, 9:42 am | #25 |
Well viewed from the top the Murphy turntable looks nothing like a standard 201. However, if it was a special then at least the mechanism underneath should look the same. Lots of pictures on this site:
http://www.gramophonemuseum.com/garrard-201.html |
17th Jan 2020, 11:05 am | #26 |
Accordingly to the information I have just read the Garrard 201 was direct drive using their induction motor, they say to adjust the speed move the “regulation plate” , what is this?
John |
17th Jan 2020, 11:47 am | #27 |
Sounds like some sort of eddy-current brake.
17th Jan 2020, 12:15 pm | #28 |
In the '70s I visited the BBC (can't remember if it was BH or not) to find out about their quick-start turntable. It was a modified 301 - I don't think they applied the mod to a 401. The machine had a subsidiary platter above the standard one. Having cued-up the record, operating a lever of some sort would lift the main turntable and with it the subsidiary platter. There were competing designs - the engineer I spoke to said "well at least ours stops!" - meaning when the subsidiary platter is at rest.
I *may* have come away with a copy of the plans but if so I've no idea where they are now. Probably cleared out in an office move. It's a long time ago. Graham
Half my stuff is junk - trouble is, I don't know which half! |
17th Jan 2020, 12:19 pm | #29 |
In this image from the gramophone museum site the centrifugal 'fly-ball' governor is visible through the bottom opening:-
Cheers |
17th Jan 2020, 12:23 pm | #30 |
Graham, is that the cueing sytem, using a piece of green felt under the disc and released for a quick start [with the turntable rotating continuously?] Or am I on the wrong track altogether
Dave |
17th Jan 2020, 12:28 pm | #31 |
Dave - sort of, a variation on the slip-mat idea. The subsidiary platter was an ally disk which I seem to remember had holes in for strobe use. It would rest on 3 supports and be lifted off the supports when the main turntable was raised. Yes, it would have to be running at full speed before raising it.
Graham
17th Jan 2020, 12:28 pm | #32 |
The quick start mech was applied to the 401 in the RP2/6. Shortly after this some design input from the BBC turned the Technics SP10 into an excellent broadcast turntable which needed no such modification to provide quick starting and was better on wow and rumble to boot. The Garrards disappeared in short order, to be replaced by SP10s and EMTs.
17th Jan 2020, 12:31 pm | #33 |
Just tried this with my 401. It comes up to speed in less than 1 second, and I strongly suspect that the 301 will be similarly quick. The motor in these decks is a real brute, and the idler wheel provides a really direct coupling method with the turntable.
I'm surprised that the BBC felt the need for some sort of record loading sub-deck arrangement. Craig |
17th Jan 2020, 1:03 pm | #34 |
I wonder if this dates back to sound effects being on record. Precise timing required by the "Grams" op.
Graham
17th Jan 2020, 1:53 pm | #35 | |
17th Jan 2020, 2:19 pm | #36 |
Isn't the platter of the Thorens TD124 idler driven albeit that the drive spindle (before the idler) is belt driven?
Alan |
17th Jan 2020, 2:28 pm | #37 |
The term "Transcription" or "Transcriptor" was also applied to some R2R decks e.g. the 1956/57 Collaro models.
Edward. |
17th Jan 2020, 2:34 pm | #38 | |
...which is an eternity in broadcast terms. The SP10 (and the direct drive EMTs) are up to speed and stable within a quarter of a turn at 78, and much less at lower speeds. Also, the drop platter was needed to give a smoother take-up of drive than that obtained by using the on-off switch, which would certainly put a clunk through the pickup if it didn't dislodge it altogether. The solenoids removed the operator's hand from the immediate area of the pickup and allowed remote operation if needs be. Last edited by Ted Kendall; 17th Jan 2020 at 2:39 pm. |
17th Jan 2020, 2:46 pm | #39 |
...which reminds me of this upcoming auction, BBC Wales:
https://www.ppauctions.com/sales.php Tasty EMT to go. Graham
17th Jan 2020, 2:52 pm | #40 |
Sadly, the only stuff that loses value faster than professional broadcast kit is networking hardware. I fully expect most of those items to go for just a few quid, and some will end up in the WEEE skip.
You're right though, the EMT and Studer decks are likely to be exceptions if they're not completely knackered. It's probable that they've seen little use, as BBC audio has been mostly digital for 20 years now. Those BBC monitors should do well too I guess. |
