19th Jun 2019, 12:38 pm | #1 |
Will these old tapes be playable?
Following a clear-out of the loft pending an insulation job, I have found over a dozen reel-to-reel tapes, unboxed, covered in unpleasant loft dust and grit. They must have been there for nearly forty years. Brushing off the dust, they look like they're still in reasonable condition. A blow from an air compressor might help further.
I'm now thinking of getting a reel-to-reel machine and doing it up as a project, in order to play these tapes, which may contain old family recordings and music. Are these tapes likely to be playable? Steve |
19th Jun 2019, 12:53 pm | #2 |
Re: Will these old tapes be playable?
Hi Steve,
Yes, they should be playable, get as much dirt off as possible first obviously! There isn't usually a problem with old domestic tapes, it's professional ones from the 80s that give most trouble. The main question is whether you need a 2-track or 4-track machine (speeds can be corrected in software if necessary). More info here: https://www.vintage-radio.net/forum/...d.php?t=103289 |
19th Jun 2019, 12:53 pm | #3 |
Surely worth a go, Steve, seeing as secondhand reel-to-reel machines can be had for next to nothing and that you'd be able to get one working with your eyes closed in about half an hour
EDIT: Crossed with Simon. Do you recall what machine they were recorded on? |
19th Jun 2019, 1:06 pm | #4 |
Hi chaps,
Thanks for the encouragement. I had rather assumed that reel-to-reel machine restoration would involve worn heads and hard-to-get mechanical parts and belts. I haven't even begun to look into this yet. Most of the tapes would have been recorded on my 1960's 'plasticky' Philips piano key recorder (long gone). Do I recall it cost £24? Some will have been recorded on my father's Ferrograph Model 5. They will be two-track. Steve Last edited by Panrock; 19th Jun 2019 at 1:11 pm. Reason: Answering a question |
19th Jun 2019, 1:13 pm | #5 | |
If you play a 2-track tape on a 4 track machine on the 'Track 3-2' setting you will get the other track playing _backwards_. This will do no damage to the machine or tape but it will let you know that it was originally recorded on a 2-track machine |
19th Jun 2019, 1:51 pm | #6 |
You are unlikely to need to replace heads.
Assuming that these are 5.75" reel tapes or smaller and 2 track recordings, you would probably be best sourcing a basic 60s British domestic machine based on the ubiquitous BSR TD2 deck. These decks are tough as old boots and rarely need more than a clean and relube. You will be able to buy one for next to nothing. If you discover that any of the tapes have particular sentimental value you can always send them away to be digitised professionally. https://www.radiomuseum.org/r/bsr_to...sis_td2td.html |
19th Jun 2019, 2:03 pm | #7 |
When you get your tape recorder before you play..Fast foward/rewind a couple of times and let them have some fresh air and breath...this will aid loosening up any sticky parts which might jam up in playback but will also bring to attention if their lube has dried out (squeaky type noises)
19th Jun 2019, 5:58 pm | #8 | |
There was a few brand new Tandy Radio Shack tapes that seemed to be wound on the reel with the oxide side out. Having never seen that type, they got binned as well. As usual, Dave US radcoll1. |
19th Jun 2019, 7:32 pm | #9 |
Dave,
Tapes that appear to be wound inside out may prove to be “back-coated” ones, they often give that impression. However, in my experience, Tandy tapes were prone to “sticky-shed” syndrome anyway so binning was not a bad idea! I’ve got some tapes with apparent mould on the edges, I’m hoping that spooling through some of those makeup removing pads may clean them. Grundig for some years supplied a little plastic fork with felt pads with their tape recorders in order to clean tapes. That’s what the two little holes along side the sound channel are for on Grundig machines. Peter |
19th Jun 2019, 10:06 pm | #10 |
You should see some of the tapes I have revived!
Give them a fast wind gently pinching a tissue around the tape just before the head bridge. You'd be amazed at how they ever survived when you see the dirt come off, and how clear they sound. You can also see during this process if there are any 'sellotape bombs' splices (sellotape oozes and sticks adjacent layers). Get some proper splicing tape in, or use the 3m Magic Tape in a pinch.
Regards, Ben. |
19th Jun 2019, 10:59 pm | #11 |
Unless it's a Grundig TK5!
Regards Martin |
19th Jun 2019, 11:16 pm | #12 | |
Most recently I used it to copy a little 3" tape my grandparents in Scotland sent over to my grandparents in Oamaru before my parents got married - it was a precious tape, and acetate so needed TLC - it's just unfortunate the one dad's parents sent over to Scotland is long gone. |
20th Jun 2019, 12:37 am | #13 |
20th Jun 2019, 4:06 am | #14 | |
As Ben points out, the best thing to do is grab a tissue and pinch it round the tape as it's coming off the reel so you catch all the gunk and crap and mold before it gets to the heads. The tape should play ok after that (presuming it hasn't gone sticky). |
20th Jun 2019, 5:07 am | #15 |
I thought the main problem with mold was the health risk, i.e. while handling or cleaning the tape the particles will fly off into the air which is not healthy to breathe in.
I would expect this can be alleviated to a large extent by doing the operation in a well ventilated area (e.g. outdoors) and wearing appropriate protection (e.g. those single use surgical masks that cover your mouth and nose). But I'm no expert and have never actually come across a moldy tape myself so just trying to contribute to the discussion here. I always feel the amount of effort put into playing a tape is proportional to what is on it. I.e. I wouldn't bin a tape that had a precious family recording on it, whatever its condition. |
20th Jun 2019, 9:49 am | #16 | |
20th Jun 2019, 10:14 am | #17 |
Some professional tapes from the 80s suffered from "sticky shed syndrome"; you will find plenty of threads about this such as:
https://www.vintage-radio.net/forum/...ad.php?t=14930 https://www.vintage-radio.net/forum/...ad.php?t=70099 Older tapes aren't affected by this. |
24th Jun 2019, 11:07 am | #18 |
re: Grundig TK5, they are hard work mostly due to numerous Wima paper caps that fail and some are tucked into quite difficult to access areas.
As others have suggested there are plenty of reel to reel machines that are much easier to work with. The Grundig TK14 is quite a good one, a more modern (mid 60's) design - mostly on one easily accessed PCB, and only two valves + magic eye.
...where on earth did that spring/screw go?? |
24th Jun 2019, 12:19 pm | #19 |
Anything with a 'Collaro Tape Transcriptor' deck fitted is going to be a pretty good bet for an easy fix for playing old tapes, so long as they're just two track.
Certainly don't bin old tapes just for the sake of a bit of dust or mould - they'll all play after a bit of a brush and blow off outside. |
10th Aug 2019, 3:46 pm | #20 |
Very interesting thread here, I'm going to look for a place to off-load my large collection of Reel to Reel, large and small, some unused, all clean and free. See you in that forum ....
