Old 19th Apr 2019, 12:41 pm   #1
OscarFoxtrot
OscarFoxtrot's Avatar
Default 706 Intercom Circuit
Further to this thread
https://www.vintage-radio.net/forum/...d.php?t=147174
which has been closed
I have now got these working as original.
1. Handset cord as 706 PCB Model.
https://www.britishtelephones.com/t706.htm
2. Regulator removed. Bell motor removed. Dial cord rewired to T numbers not PCB tags. Unused dial wires removed.
3. Strap: T18-19, Wire link: T13-19, T9-16, T8-10 (that is link 13 and 19 only, not 13-14-15-etc)
4. Insert Res 1k 5% (brown-black-red-gold) T4-T16.
5. Dial Grey (Slate) T11, Blue T12, Brown T13.
6. Buzzer Orange (+) T12, Black (-) T4.
7. 9 volt + T19, - T4 (master only)
8. Line cord Green T4, Blue T6, Whi T8, Red T18.
The two phones are connected with 4 way line cords to matching colours. Only the master has a 9v battery or power source. Both phones are otherwise identical.
I shall be pleased to receive comments/errata.
Name:	706 Intercom.jpg
OscarFoxtrot is offline
Old 19th Apr 2019, 1:25 pm   #2
OscarFoxtrot
Default Re: 706 Intercom Circuit
Erratum no 1: insert link T6-T11
Old 19th Apr 2019, 1:33 pm   #3
TonyDuell
As shown, that added 1k resistor doesn't seem to do anything (it goes to a capacitor, the other end of which is not connected). Should T8 and T9 be strapped?
TonyDuell is offline
Old 19th Apr 2019, 1:57 pm   #4
OscarFoxtrot
No, T8-9 not strapped. The only strap is T18-19, and wire links T6-11*, T8-10, T9-16, T13-18. *Not on dwg.
Oh well, although the speaking isn't great it does work. I'll have another look later.
Old 19th Apr 2019, 6:45 pm   #5
OscarFoxtrot
Erratum no. 2: T8-9 is strapped. Apologies. Amended dwg attached.
Old 19th Apr 2019, 7:47 pm   #6
OscarFoxtrot
Some photos.
I note that both my grey ones (obtained from different sources at different times) have the 'test plastic' label. They're moulded from much thicker than normal plastic - maybe rigid PVC?
ID:	181532   Click image for larger version
ID:	181533   Click image for larger version
ID:	181534   Click image for larger version
Old 19th Apr 2019, 11:14 pm   #7
OscarFoxtrot
Video (not mine) here
https://www.youtube.com/watch?v=T6NjF_G-RYo
Old 20th Apr 2019, 12:39 pm   #8
Oldcodger
OF- sounds like a similar idea to the kit used on a planset n625 with internal extensions, but using a button on the top of the 706 to call the other handset. Mentioned it as you may not have seen this . remembrance from my Muirfield days( or was it Muirhouse , somewhere in a rough partof the city)
Oldcodger is offline
Old 20th Apr 2019, 12:53 pm   #9
OscarFoxtrot
It might be interesting to compare the circuit.
The video mentioned above shows one of the switchhook contacts has been cut from the PCB, I didn't notice that on mine.
Old 20th Apr 2019, 5:04 pm   #10
OscarFoxtrot
I also don't see where brown (D3) connects to, as the only wires connecting to the dial are Brown, Blue and Grey (Slate).
