18th Jan 2017, 11:04 pm | #21 |
Re: Murphy U502 voltage readings
I think this fault may date back a good few years. It is only recently that I have been tackling it. There are still some wax capacitors left in, would it be worth replacing these?
David |
18th Jan 2017, 11:43 pm | #22 |
19th Jan 2017, 11:33 am | #23 |
Replace all the paper capacitors David; I think we had all assumed that from your first post.
These are the ones to change if you haven't already done so: C44 0.01uF This component won't be responsible for your symptom but it must be changed to avoid damage to the output stage. C21 0.003uF C24 0.01uF C25 0.01uF C28 0.003uF C31 0.01uF C37 0.01uF C42 0.01uF C46 0.02uF Check the component list in the service data and use capacitors of the same or higher working voltage for replacements. Check all your work and make sure you haven't made any wiring errors. C22 and C29 (both 1800pF) are also vital to the stability of the I.F. amplifier but they are ceramic types and unlikely to be faulty; only investigate them if you still have the symptom after changing the paper capacitors. |
19th Jan 2017, 11:46 am | #24 |
Colin, thanks for the list. Yes I still have some to do and it's going to take a while.
Regards, David |
19th Jan 2017, 1:26 pm | #25 |
Good luck.
22nd Jan 2017, 1:37 pm | #26 |
Well, all capacitors on the list now replaced and it's a success. The little Murphy VHF set is now back together and working. Thanks for the help I have received. This has been my first vintage set recovery. The next one is a Marconiphone.
David. |
