Old 7th Sep 2006, 9:17 am   #1
wireless_paul
wireless_paul's Avatar
Location: World Heritage Village of Saltaire, Shipley, West Riding of Yorkshire.
Default Obtaining Chassis and cabinets
Hello.
Wondered where you can obtain blank chassis and cabinets from or where you can get them made. For example the one I am looking for at the moment is 7x10x2in, although the original design (H.F. Bands-Superhet) with 4 valves might increase to 7 valves with the addition of a BFO, crystal calibrator and voltage regulator this size might increase! The front panel is 7x10in.
Thanks.
Paul
wireless_paul is offline
Old 7th Sep 2006, 9:27 am   #2
mickjjo
mickjjo's Avatar
Default Re: Obtaining Chassis and cabinets
Hi Paul, Might be worth trying this outfit:-
http://www.bluebellaudio.com/
They seem to do a good range of chassis:-
http://www.bluebellaudio.com/enclosuresalu.htm
Regards, Mick.
mickjjo is offline
Old 7th Sep 2006, 12:39 pm   #3
Biggles
In the past I have used aluminium sheet and bent it to shape in a metal press (very useful having a paint/body repair shop at work) or the other trick I have used is turning an aluminium pre manufactured box from Maplins upside down, mounting the valve bases etc on the "bottom" and using the "top" as a bottom cover. The range of sizes that they do is a bit limited though. They used to make a dedicated aluminium chassis in two sizes but this may have been discontinued now.
Biggles
Biggles is offline
Old 7th Sep 2006, 5:57 pm   #4
Dave Moll
Dave Moll's Avatar
Unless, of course, you fancy something a little more whacky
Dave Moll is offline
Old 7th Sep 2006, 6:31 pm   #5
mikelect
mikelect's Avatar
Hi Paul, these guys specialise in making chassis any old size you want at reasonable prices
http://www.isoplethics.co.uk/
HTH Mike
mikelect is offline
Old 7th Sep 2006, 6:48 pm   #6
YC-156
YC-156's Avatar
Something worth keeping in mind is that for above-MW frequencies you probably want a really, really strong chassis for the main frequency determining parts of the circuits, like VFOs and other oscillators in particular. That includes anything, which carries mechanical forces to the main tuning cap, like tuning dials and more. So for good performance you should plan to use and make room for sub assemblies housed in, say, diecast Aluminium cases.
Most of the off-the-shelf Aluminium chassis' available are way too flimsy for stable HF operation. No problem for the Hi-Fi enthusiast, of course, but you will probably need more.
Rule of thumb: If you can bend or flex anything using only your bare hands and arms (yes, simultaneously), then it probably isn't strong enough.
Frank N.
YC-156 is offline
