Reply
Old 24th Nov 2023, 1:44 pm   #1
Keith956
Keith956's Avatar
Default Hacker VHF Herald RP37
I have one of these - a Freecycle find. It has a mains adapter inside that has been fitted in the distant past. It seems to work apart from a problem with the aerial. I'm not sure if it is jammed or what, but it won't extend with a careful tug with pliers. It seems to be well and truly seized.
Anyone know of a source for a replacement aerial, or how to unseize it?
Keith956 is offline   Reply With Quote
Old 24th Nov 2023, 2:21 pm   #2
Vicboduk
Default Re: Hacker VHF Herald RP37
Unfortunately, what you have there is just the mounting hub at the end of the aerial.
All the telescoping sections have broken off! You will need a replacement.
Sorry I don’t know of a source but I suspect other members will, and be able to give you the correct length if sourcing an alternative.
Vic
Vicboduk is offline   Reply With Quote
Old 24th Nov 2023, 2:55 pm   #3
Station X
Station X's Avatar
How long is the aerial in its unextended state? There may a 'U' shaped "catch" which the top end snaps into, or does it retract into the case?
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 24th Nov 2023, 3:09 pm   #4
Nickthedentist
Nickthedentist's Avatar
Vic is right.
Nickthedentist is online now   Reply With Quote
Old 24th Nov 2023, 4:31 pm   #5
Paul_RK
Paul_RK's Avatar
From one of the letters to dealers that Nick kindly gave the Hacker group many moons ago, all available in the group's Photos section, the original aerial is 9mm. diameter, 190mm. long.
Paul
Paul_RK is online now   Reply With Quote
Old 24th Nov 2023, 5:05 pm   #6
Squipper
Squipper's Avatar
I've used these before on Hackers, several times - specifically in my case the Hunter model. There's no knuckle, and you'll need a replacement screw / cleat to attach the antenna wire. (Or just solder the wire direct)
https://www.aliexpress.com/item/33058005963.html
The waves I have discovered will not have any practical application - Hertz
PAUL - BVWS Member
Squipper is offline   Reply With Quote
Old 24th Nov 2023, 5:28 pm   #7
simpsons
Hmmn
For FM I've always found that the aerial needs to be angled at say 45 degrees to get good reception in a room setting.
Given its a Hacker and, the aerial is secured with a P clip, a Roberts R707 telescopic aerial would be my choice. It is well made, has both a knuckle joint and ball bearing horizontal lock and will match the quality of the radio you have.
Ask for one in the want's post.
Best of luck
Chris
simpsons is online now   Reply With Quote
Old 24th Nov 2023, 6:32 pm   #8
Keith956
Keith956's Avatar
Thanks all,
It was a bit optimistic hoping the aerial was just seized, the Roberts replacement sounds a good idea. I’ll check I haven’t got anything suitable in the garage before putting out a wanted request though.
Keith
Reply
