Reply
Old 15th Sep 2023, 9:20 pm   #1
biorapter2321
Default Ericsson chart recorder machine.
Can anyone identify this piece of equipment, its seems to be a kind of chart recorder maybe from a telephone exchange? It's very heavy. Thanks in advance
ID:	285040   Click image for larger version
ID:	285041   Click image for larger version
ID:	285042   Click image for larger version
ID:	285043   Click image for larger version
biorapter2321 is offline   Reply With Quote
Old 16th Sep 2023, 9:26 am   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: ericsson chart recorder machine
Yes it is a chart recorder, not specifically for use in a telephone exchange, it could have found a use in a whole range of industries for recording things like furnace temperature, pressures in various parts of a chemical plant, voltages and currents in a transmitter, water levels in a pumping station or sewage works.... The list is endless.
Old 16th Sep 2023, 4:21 pm   #3
g8jzyian
Default Re: Ericsson chart recorder machine.
Hi
it is a chart recorder but are there 10 electromagnets at fig5?
when they are operated do they make a mark on the paper from the typewriter ribon that I spot on the side view?
If so I have used a similar device to assess traffic in a strowger exchange.( many years ago).
Regards
Ian
g8jzyian is offline   Reply With Quote
Old 16th Sep 2023, 4:56 pm   #4
Graham G3ZVT
Graham G3ZVT's Avatar
I think the ten actuators move each of the ten pens +&- laterally on the moving paper. Think of the Polygraph in any number of 1950s psycological thrillers.
Graham.
G3ZVT
Graham G3ZVT is offline   Reply With Quote
Old 17th Sep 2023, 1:23 pm   #5
ScottBouch
ScottBouch's Avatar
I have seen panel mounted chart recorders used in old industrial machinery (gas turbines) to record vibration levels, pressures, temperatures etc... If its industrial, and of the right age, the inputs may be 4 to 20 mA current loop which became an industrial analogue signal standard in the 1950s.
www.scottbouch.com
ScottBouch is offline   Reply With Quote
Old 17th Sep 2023, 2:48 pm   #6
biorapter2321
Default
thanks for the replies, ill have to make an educated guess about the electromagnets when i see it, it uses a strange kind of plug so i cant really test it
here are some close ups of the chart paper and the plug, also the top clear cover can slide away so the operator can make write notes on the paper
ID:	285115   Click image for larger version
ID:	285116   Click image for larger version
ID:	285117   Click image for larger version
Old 21st Sep 2023, 10:56 am   #7
ScottBouch
ScottBouch's Avatar
Could your connectors be part of the "Multicon" or 159 series?
https://www.casa.co.nz/connectors/mu..._3p_Secure.pdf
Some dimensions are given in the PDF - may help you to identify them.
Found under the manufacturer names of: Jones, Painton and Plessey.
https://www.gracesguide.co.uk/Painton
In 1969 Painton was acquired by Plessey Components. Not sure where Jones fits into the picture.
Cheers, Scott
www.scottbouch.com
Reply
