Old 25th Aug 2023, 11:02 am   #1
ScottBouch
ScottBouch's Avatar
Default Aluminium cased telephone speaker standards
Hi all,
In the attached images you will see on the left the speaker from the handset of a 746 telephone, next to it on the right is a speaker from a MK4A flying helmet headset.
The telephone speaker is a nominal 45mm in diameter, and the helmet speaker is a nominal 40mm in diameter.
Apart from the size and electrical differences, they follow the same form, case with recess for two terminal posts.
Now, does anyone know where these standard forms and dimensions are defined? Is it a GPO / Ministry of Supply standard, or BS etc...? are there standards for the electrical characteristics too?
I'd love to gain some proper understanding of this type of speaker casing, and the origins.
What companies manufacture speakers to these standards?
Many thanks, Scott
ID:	283960   Click image for larger version
www.scottbouch.com
ScottBouch is offline
Old 25th Aug 2023, 12:24 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Aluminium cased telephone speaker standards
The ones I remember were made by A.P. Besson, who later became Besson Hosiden.
G6Tanuki is offline
Old 25th Aug 2023, 1:29 pm   #3
Nickthedentist
Nickthedentist's Avatar
Seconded.
The GPO ones usually have a manufacturer’s code stamped on them.
Nickthedentist is offline
Old 25th Aug 2023, 1:48 pm   #4
ms660
ms660's Avatar
Item on the left in 2nd photo, TMC, Bathgate, West Lothian.
Lawrence.
ms660 is offline
Old 25th Aug 2023, 2:00 pm   #5
Roger Ramjet
I have come across burglar alarm sounders that use a similar earpiece receiver powered by a 12v oscillator. These were known as BESSON BANDITS so me be part of same family ?
Rog
Roger Ramjet is offline
Old 25th Aug 2023, 2:38 pm   #6
ScottBouch
ScottBouch's Avatar
Brilliant, you guys have pointed me in the right direction! thanks!
"Rocking Armature Transducers":
https://www.royalsignals.org.uk/inse...inserts_en.pdf
I have seen Besson on the back of some of the flying helmet speakers, this now makes a lot of sense.
Searching online for Rocking Armature Transducers there seem to be a few 'made in China' alternatives out there too.
Many thanks, Scott
www.scottbouch.com
Old 25th Aug 2023, 2:43 pm   #7
ms660
ms660's Avatar
A.P. Besson codes, DAD and DAE.
Lawrence.
ms660 is offline
Old 25th Aug 2023, 3:54 pm   #8
ScottBouch
ScottBouch's Avatar
I have just eyeballed a few of these ex-military ones, and few are marked with A.P. Besson, some with NSN: 5956-99-620-5675, some with other codes.
I guess the customer can specify whatever markings they want!
www.scottbouch.com
Old 28th Aug 2023, 9:04 pm   #9
McMurdo
McMurdo's Avatar
It's Hosiden-Besson, when AP Besson became a subsidary of japanese giant Hosiden.
My workshop internal alarm sounder is a Besson Banshee, and uses one of the earpiece-style inserts, as many industrial sirens did. Some GPO switchboards and 700-series phones used DC bleepers in the same casing.
Kevin
McMurdo is offline
Old 30th Aug 2023, 6:37 am   #10
dagskarlsen
dagskarlsen's Avatar
I do not know these well! Still I have measured out DC resistance from around 40 ohms up to several hundred ohms. Cant remember how much, but at least more than 200 ohms.
dagskarlsen is offline
Old 30th Aug 2023, 7:11 am   #11
Nickthedentist
https://www.britishtelephones.com/menureci.htm
https://www.britishtelephones.com/gp...recin4t_02.jpg
http://www.samhallas.co.uk/repositor...telephones.pdf
Old 30th Aug 2023, 11:13 am   #12
ScottBouch
ScottBouch's Avatar
Hi Nick, that information is fantastic, thank you!
Funny how those are two websites I've come across during my aviation based research where certain parts (such as some particular relays I was researching) were common to the Air Ministry and the GPO.
Cheers, Scott
www.scottbouch.com
