Old 29th Jun 2019, 12:55 pm   #1
bobbyd123
Default Bush DAC90 Asbestos Problem
I recently picked up this bush DAC90 The case is in good condition
I already have a Bush DAC10 Waiting for parts (Capacitors resistors)
I am not sure how or what to do with what may be asbestos around the dropper resistor (Photos attached)
I have not touched the radio so I don't no if the dropper is okay
I am hoping that you will be able to instruct me as to what is the best way forward to do this job Thank you!
ID:	185894   Click image for larger version
bobbyd123 is offline
Old 29th Jun 2019, 1:26 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Bush DAC 90 Asbestos Problem
If it is ok (the dropper) I might be tempted to hold a vac near it to suck up any loose fibres and then leave it.
To replace it I would wet it carefully first outside before touching.
HamishBoxer is offline
Old 29th Jun 2019, 1:33 pm   #3
Maarten
Holding a vac near it would spread the asbestos fibres instead of containing them. It would be much better to do nothing if the only alternative is using a normal vac.
The vac should not only have industrial HEPA filtering, but also be constructed in a way that no fibres can escape or stay behind when emptying the bag.
Maarten is online now
Old 29th Jun 2019, 2:28 pm   #4
crackle
Paint all the asbestos with diluted PVA glue, trying not to get any on the dropper.
Mike
crackle is offline
Old 29th Jun 2019, 2:34 pm   #5
ColinB
ColinB's Avatar
With all due respect, this is bad advice. They will pass straight through a standard cleaner and then be sprayed around the room.
Moving all the fibres around with a vacuum cleaner is the last thing you should be doing!
Disturb the asbestos as little as possible!
ColinB is offline
Old 29th Jun 2019, 2:57 pm   #6
Mike. Watterson
Soak it in fast setting step and sill repair cement.
Never disturb or remove asbestos unless you have the training, certification, insurance and equipment.
It's perfectly safe stabilised with cement as long as not subsequently cut, drilled, sawed, filed or disturbed.
Same applies to radium based glow in in the dark paint. Put FRESH luminous paint (it's the pigment that wears out) and then acrylic or polyurethane varnish. Never try to remove it.
In both cases it's the inhaled dust that is the hazard.
Mike. Watterson is offline
Old 29th Jun 2019, 4:48 pm   #7
bobbyd123
I had no Idea that they could be so dangerous
It's a shame because I am new to this hobby
Looks like there is no solution
I suppose I will have to bag it and send it off to the dump
Thanks anyway
Old 29th Jun 2019, 5:08 pm   #8
HamishBoxer
No, don't dump it. As suggested PVA glue watered down across it, then leave alone.
I have one sat here and I certainly will not be disposing through asbestos.
Old 29th Jun 2019, 5:19 pm   #9
Murphy Maniac
Murphy Maniac's Avatar
No! Definitely don't dump it. Many things are dangerous if incorrectly handled, including electricity. If you follow the advice about sealing it and then don't poke about with it unnecessarily all will be fine.
Geoff. (BVWS Member)
Murphy Maniac is offline
Old 29th Jun 2019, 5:30 pm   #10
M0FYA Andy
Don't get paranoid! Follow the advice to soak it in dilute PVA glue.
Andy
M0FYA Andy is offline
Old 29th Jun 2019, 7:37 pm   #11
TimLiggins
It 's bonded asbestos. There is not one iota of documented evidence that anyone has ever been harmed by the stuff. I speak as a retired health and safety professional.
TimLiggins is offline
Old 29th Jun 2019, 7:51 pm   #12
ms660
ms660's Avatar
Bits of it don't look very bonded to me
Lawrence.
ms660 is offline
Old 29th Jun 2019, 8:22 pm   #13
ajgriff
ajgriff's Avatar
I'd love to see a definition of 'bonded asbestos'. Would old Artex be classed as such? If so, there is plenty of evidence that when the stuff is drilled, scraped, prodded or, worst of all, sanded asbestos fibres can become airborne with obvious potential risk. Painted and left alone it should be fine however.
Back to the DAC 90 though, I certainly wouldn't give up on it either. It's really case of understanding the risk and acting accordingly.
Alan
ajgriff is offline
Old 29th Jun 2019, 8:48 pm   #14
HamishBoxer
Yes I had Artex tested at the last house prior to sale and no it was clear.
Old 29th Jun 2019, 9:39 pm   #15
bobbyd123
Thanks to you all
So my first job
Pick up some PVA Glue and do as instructed to seal the asbestos
I can do this out side in my remote garage. The roof sheets are also asbestos
Warning Sign (Danger Do not climb Asbestos Roof! ) that's it
How long after treatment should I leave it before I can start my restoration I would guess around a couple of weeks
(Thanks again.)
Old 29th Jun 2019, 9:55 pm   #16
Radio_Dave
Radio_Dave's Avatar
I would be wary about using PVA glue because it's not heat resistant. If it flakes or peels you could have more trouble on your hands.
Radio_Dave is offline
Old 29th Jun 2019, 10:13 pm   #17
Philips210
Hi
I've read in many places of using diluted PVA applied to asbestos to hold together the fibres which seems to be very effective. This applies particularly to out buildings which have asbestos roofs.
My only concern in its use in a valve radio is how well will it cope with the heat being close to the voltage dropper?
The suggestion of using repair cement by Mike. Watterson is a good idea which should cope with heat very well.
Regards,
Symon
Philips210 is offline
Old 29th Jun 2019, 10:54 pm   #18
Philips210
Hi.
Reading about asbestos in Artex a few years back came as quite a shock to me. Back in the early 1990s, I decided to install plaster coving to all the ceilings in our bungalow. When it was new in 1984, the bungalow had Artex ceilings with a smooth border close to the walls. To maintain the smooth border after fitting the new coving, I scraped off the Artex 1.5 inches in from the coving. I dread to think how much asbestos I've inhaled but I'm not going to lose any sleep over it. I wonder about how much exposure the builders had when mixing the stuff.
My late father told me when he was about 17, how he and his work mates used to knock through ceilings in bomb damaged properties during WW2. Apparently, many of these properties had asbestos in them. People were oblivious to the potential dangers.
Regards,
Symon
Old 30th Jun 2019, 7:55 am   #19
stitch1
stitch1's Avatar
I also have a DAC90 availing attention. When I get around to it I intend to take the same approach as coopzone, replacing rather than stabilising removing the asbestos once and for all.
https://vintage-radio.net/forum/showthread.php?t=148000
It’s a very small amount and a one off job so I believe the risk is minimal but I’ll still do it outside and bag it up.
Our NHS site talks about the risk and says.
When the dust is breathed in, the asbestos fibres enter the lungs and can gradually damage them over time. But you would need prolonged exposure to asbestos fibres, usually over many years, before you develop asbestosis. I’ve only got one so my risk assessment concludes don’t worry just get it out.
https://www.nhs.uk/conditions/asbestosis/
The official view of procedures for removal from a ‘period’ appliance is here:
http://www.hse.gov.uk/pubns/guidance/a32.pdf
John
stitch1 is offline
Old 30th Jun 2019, 8:27 am   #20
stevehertz
stevehertz's Avatar
Are you not reading the same replies as I am?!
stevehertz is offline
