Old 21st Aug 2023, 3:03 pm   #1
Angler49
Default Vintage Italian onyx phone
Hi my wife has just bought a vintage Italian onyx phone the line works but the ringer doesn't upon investigation there is only 2 wires connected and two that isnt the ones connected are the red and white one the two that aren't are green and red ones does anybody know which wire goes to to wherever to mate the ringer work thanks in advance les
Angler49 is offline
Old 22nd Aug 2023, 5:10 pm   #2
Roger Ramjet
Default Re: Vintage Italian onyx phone
Hi les,
Firstly welcome to the forum.
If you have a current linebox / master socket the applicable configuration for connecting a ringer is 3 x wires (although some non approved imports can be two wire).
It is difficult to answer you query without knowing where the non connected wires go to. Ideally, a clear picc'y of the internal wiring oor af a rough sketch may help.
Rog
Roger Ramjet is offline
Old 22nd Aug 2023, 6:38 pm   #3
Dave Moll
Dave Moll's Avatar
Am I reading correctly that there are two red wires, one of which is connected and the other isn't? If there were a blue wire, I would have advised connecting it to the position adjacent to the red one as a first try.
Dave Moll is offline
Old 23rd Aug 2023, 11:34 am   #4
Angler49
Originally Posted by Roger Ramjet View Post
Hi les,
Rog
hi Roger I have took a photo the terminals are number 1 to 13 left ot right red is connected to number 10 and white connected to number 11 I hope this helps les
Angler49 is offline
Old 23rd Aug 2023, 2:39 pm   #5
Roger Ramjet
Yes that a bit clearer Les,
There should be two internal wires from the bell coils
One should should connect to the existing white wire termination.
The other bell wire goes to the blue of the line cord but this has had the lug snipped off so you will need to make a joint & tape up rather than connecting to anything else.
Should work provided the other end of the line cord has a standard BT plug on the end which has not been tampered with.
However, this extra bell may upset the REN balance of you internal phones if you already have others phones plugged in as well. In other words, none will ring on an i/c call.
Rog
Roger
Old 23rd Aug 2023, 5:57 pm   #6
Dave Moll
Dave Moll's Avatar
Ignore my previous post. For some reason I was thinking you were referring to connections at the far end of the line cord. I really ought to desist from posting when I'm tired!
As Roger says, if you can find a terminal connected to the end of bell coil not connected to the terminal with the white wire, the blue wire need to connect to it - as long as there is a connection back to the ringing capacitor in the master socket.
Alternatively, if the end of the bell coil is connected to a capacitor, connect the other end of the capacitor to the same terminal as the red wire, and leave the blue wire unconnected.
Old 24th Aug 2023, 8:08 am   #7
dagskarlsen
dagskarlsen's Avatar
This phone is probably made for non-UK ringer circuits.
The strap between Ø9 and Ø10 is probably made for letting the ringer work on the 2 wires.
Something may have been modified, or disconnected by a previous owner in hence to not get to high REN load on the line. Moving the white wire from 11 to 12 or 13 may get it ringing, but you will probably not be able to speak, that test will show us where the connection between 11 and?? was when it was used in non UK systems.
When we know that we may ind out where you should put your third wire.
dagskarlsen is offline
Old 24th Aug 2023, 10:09 am   #8
Nickthedentist
Nickthedentist's Avatar
Does this have the green circle and "BABT approved" label underneath, or is it definitely a grey import?
Nickthedentist is online now
