6th Apr 2018, 7:07 pm | #1 |
Sony TC206SD
3Hi just trying to have and look at this tape deck. It wouldn't play tapes so I got a new set of belts. Now it runs very fast. I have tried to adjust the speed control it does speed up and down. When at its lowest the tape still runs fast. Would anyone have any idea how I can slow it down
Thanks mark Last edited by rockinmark; 6th Apr 2018 at 7:10 pm. Reason: Photos |
6th Apr 2018, 8:17 pm | #2 |
Re: Sony TC206SD
If it has a pinch roller solenoid make sure the armature/pivot/lever mechanism is operating correctly. If there is any stickiness (old lubricant) in either/all of these, the 'take-up' reel drive motor will tend to pull the tape through rather than the capstan spindle & pinch roller combination.
This can also manifest itself as reduced/total loss of output if the tape is not in contact with the playback head. Guy
"What a depressingly stupid machine." [Marvin: HHGTTG] |
6th Apr 2018, 10:24 pm | #3 |
Re: Sony TC206SD
If you have fast and slightly uneven speed, and all the belts are on the right pulleys (no 'riding'), the motor control IC is toast. Replace the speed pot first in case it is bad /worn.
Regards, Ben. |
7th Apr 2018, 9:34 am | #4 |
Re: Sony TC206SD
How do I check that Ben and what I need to change it does speed up and down but not down enough
7th Apr 2018, 10:25 am | #5 |
Re: Sony TC206SD
First look on the pot for any markings, replace with same. If not, you will need to use the schematic.
Regards, Ben. |
7th Apr 2018, 9:23 pm | #6 |
Re: Sony TC206SD
Very unlikely that the pot has failed, even more unlikely is the drive chip
8th Apr 2018, 2:13 pm | #7 |
Re: Sony TC206SD
Make sure you have belts on the correct parts of the motor pulley, it can be any easy to mistake to get them around the wrong way, the only time I came across a motor control ic that faulty it was running red hot with absolutely no affect on the motor speed
Gary |
8th Apr 2018, 3:38 pm | #8 |
Re: Sony TC206SD
Blimey, I must have been unlucky then.
I have had the motor IC fail on numerous units that have passed through my hands over the years. Such as: late 70s Panasonic/Technics decks (M215?), one deck of an an AIWA RX20, a Triumph TC400, a Dual/Bettor music centre, to name just a few. It is noteworthy that these were mostly 'powered' soft touch mechs. In all cases, the symptoms were the same. Speed at least 15% faster and varying. The tricky ones have the IC inside the actual motor.
Regards, Ben. |
9th Apr 2018, 6:13 pm | #9 |
Re: Sony TC206SD
I don't think the belt could go in any other place on the pulleys
9th Apr 2018, 8:13 pm | #10 |
Re: Sony TC206SD
ben
Wow that is a list! I never knew that other companies back then used Sony motors and boards. rockinmark In my foggy memory there were 2 belts driven off the motor, lower one for the capstan and an upper one for the FF/REW and autostop , though at my state of mind I am prepared to accept I am wrong |
9th Apr 2018, 9:42 pm | #11 |
Re: Sony TC206SD
They weren't all sony motors/boards. The only thing they had in common was the fault symptoms!
Regards, Ben. |
11th Apr 2018, 6:07 pm | #12 |
Re: Sony TC206SD
Ok ben
I understand Thanks Gary |
11th Apr 2018, 8:48 pm | #13 |
Re: Sony TC206SD
Yes it has 2 belts the larger flat one for the capstan
18th Apr 2018, 11:51 pm | #14 |
Re: Sony TC206SD
If you never had this unit running correctly before, You might check to see if the capstan pulley is a 50 cy or 60 cy one. I know here we had to change a lot of the overseas pulleys as the tapes (and record players) ran at the wrong speeds. (60 cy here in the U.S.)
Putting the belt on wrong, getting a twist in it, or having it ride up on the edge of a pulley can cause the overspeed condition too. I never had that happen to me. Nope. Unnuh. And I stick to that statement. :P |
19th Apr 2018, 11:12 am | #15 |
Re: Sony TC206SD
That is only the case with AC mains motors, In this case it seems to be a low voltage DC type which of course is unaffected by the mains frequency!
Regards, Ben. |
