26th Mar 2018, 7:02 pm | #1 |
Unscrewing wooden bell pushes
Among the items I brought home from the BVWTM sale yesterday were a few old wooden bell pushes. They consist of a wooden base with a male thread onto which screws a wooden cover. There are 2 contacts on the base, the button fits into a hole in the cover. I am sure you know the sort of thing.
Anyway, I can't unscrew the covers on two of them, and I wonder if anyone has any tips/tricks for separating stuck wooden threads. If it was metal I'd have a few ideas, but not for wood. So far I've tried to grip them with a 'Boa' strap wrench, I've tried to tighten them slightly, and I've run a knife blade round the join on the outside to remove any paint/varnish. Nothing has helped. |
26th Mar 2018, 7:25 pm | #2 |
Re: Unscrewing wooden bell pushes
Heat the screw with a soldering iron?
Mike. |
26th Mar 2018, 7:29 pm | #3 |
Try putting it in an airing cupboard, which will make the wood shrink slightly.
26th Mar 2018, 7:35 pm | #4 |
26th Mar 2018, 7:35 pm | #5 |
26th Mar 2018, 7:46 pm | #6 |
Tony I to bought a few and have used a hair dryer on then.i have ised small amounts of vegetable oil applied in the gap with s strange to lubricate the thread.Ineeded some to go with the two flag indicator box I have from a late relatives house.
Regards Robin |
26th Mar 2018, 8:12 pm | #7 |
Also try tightening slightly before untightening. I've used that technique often for all sorts of threads and surprisingly it often works!
26th Mar 2018, 8:34 pm | #8 |
If at some point the whole has gotten damp it might be due to uneven drying or acclimatization, the outer (think of it as a nut) will have a lower volume than the inner (think of it as a screw) so it will dry out faster and shrink on to the screw, dry the whole lot out very gently (no direct heat) over a week or so then give it another go.
Lawrence. |
26th Mar 2018, 8:41 pm | #9 |
Its a very coarse thread turned on both parts. Dry it out thoroughly and it will release, it may take quite a long time but do it slowly to avoid splitting.
26th Mar 2018, 9:28 pm | #10 |
How about putting the bell-push in a plastic bag and placing it in the dry environment of a freezer few days?
I recently put a large wooden TV cabinet in the freezer for a week, in order to kill woodworm. It came out completely undamaged. Yes, I'm amazed that SWMBO allowed me to too.
-- Graham. G3ZVT |
