Old 24th Aug 2017, 1:14 pm   #1
simonmavity
Default Mullard high speed valve tester cards
Hi. I hope all is well. I am an untrained amp tech and have bought a high speed tester not realizing it needs cards to work. I read GMB has put together a database of cards. Any help would be nice. Thanks in advance.
simonmavity is offline
Old 24th Aug 2017, 9:02 pm   #2
Ed_Dinning
Default Re: Mullard high speed valve tester cards
Hi Simon and welcome to the forum, you will find lots of data about the cards and how to make them(!) on the thread in the forum.
You may get lucky and find a set of cards on e-bay, but it is unlikely to be a full set and you probably would not want it anyway.
Your set should at least have the "mains", "HT" and "reject" cards to allow setting up.
While waiting for the cards you might like to check over the electronics, being valve operated it suffers from all the problems of leaky caps and resistors gone high.
Ed
Ed_Dinning is online now
Old 24th Aug 2017, 11:43 pm   #3
frankmcvey
Hi, Simon.
HSVTs get neglected and die; the cards live forever. You'd think there would be hundreds of sets of orphaned cards available, but actually they don't come up very often and they're quite hard to come by. There is a set on Ebay at the moment with a wildly optimistic buy-it-now price of £569.
I have a jig for manufacturing cards and can help you out with the 3 test cards. Unfortunately, they wouldn't be freebies. The cards are made from 0.8 - 1.0mm SRBP sheet, which isn't cheap.
You'll be extremely lucky if the tester works properly straight out of the box - they usually require a lot of fettling, as Ed has pointed out. Unless the machine has been in recent use, at the very least the electrolytic caps will need reforming, so don't apply full mains - go through a lamp limiter.
If your machine is the Mark 4, it's relatively easy to work on. However the earlier marks weren't built with maintainability in mind, so the passives are a lot less accessible, and the style of solder tags used make component replacement much more difficult.
Fortunately there is plenty of documentation available for all 4 marks of the tester available on GMB's website here (bottom of the page)
Be aware as well that this is basically a green for good, red for bad and amber for ok-ish machine. It's not a characteristic tester, and it won't allow you to accurately match valves.
On the plus side, they're easy to use and pretty bulletproof once they're serviceable, with no delicate meters to fry if you get a switch or a pot wrong! And, as Ed says, as an amp tech you'll just be looking for a relatively small number of test cards for the more common audio valves and rectifiers.
Good luck with it, and PM me if you're interested in the test cards.
Frank
It might be a bit late for you now, but I wrote a brief blurb on buying HSVTs some time ago. It's here.
frankmcvey is offline
Old 27th Sep 2017, 12:38 pm   #4
One post moved to a new thread here:-
http://www.vintage-radio.net/forum/s...d.php?t=140133
Station X is offline
