9th Jun 2013, 12:35 am | #1 |
LG VHS LV710 Broken Off Spindle ?
With its NTSC Playback facility , this could be useful. Picked up at the dump , something inside rattling around. Opened up case and there is a 3/4in approx rubber brass bushed thing not connected into anything. Looks like , if it is for any purpose ( pinch roller ? ) and not something not part of the unit that was pushed through the cassette door , there looks to be only one spindle it could fit on ( it appears to have a step half way through it ) but there is no obvious retaining clip , pin or cover that I can see to hold it on. Obviously I dont have a service manual , and probably not worth getting one , but if anyone has experience of VHS repairs for this model that assuming no other faults, ( I have not tested as yet ) it might become a useful object to someone.
Thanks. |
9th Jun 2013, 1:00 am | #2 |
Administrator
Re: LG VHS LV710 Broken Off Spindle ?
I've moved this to "Vintage TV and Video" as we regard all consumer video cassette recorders as "vintage" now.
9th Jun 2013, 10:21 am | #3 |
From memory I sure this may be a guide post next to the video heads. I have seen this many times where the press fit brass insert has come loose. I used to super glue them back in place and had no further problems.
9th Jun 2013, 10:33 am | #4 |
Possibly the impedance roller, which is to be found on the LH (supply) side of the tape path.
N. |
9th Jun 2013, 10:46 am | #5 |
A few photos of the deck and the stray part would be a great help, I have a couple of LG videos here, so might be able to help.
Mark |
