8th Aug 2018, 5:27 pm | #1 |
Air Ministry Wire Recorder
Another long shot - I seem to specialise in asking for information about mystery items nobody knows anything about!
Does anybody know anything about this Wire Recorder, please. It has an Air Ministry Stores Reference, and I've found a link to an A.P. number (A.P.2487L), but this isn't listed in the online catalogue at TNA, Kew. It only has a single valve inside (an ECC82), so I'm guessing it must have worked with another electronics unit. Has anyone seen one before? Many thanks, Andy |
8th Aug 2018, 5:44 pm | #2 |
Re: Air Ministry Wire Recorder
8th Aug 2018, 6:07 pm | #3 |
I was going to say it looked like a Boosey and Hawkes unit that Henry's Radio sold (as surplus) at one point. I never could afford one back then though.
8th Aug 2018, 6:43 pm | #4 |
I've had one of these for ages. Don't anything about it apart from the 'No.14 MU Radio Workshop' lable on it.
Ging |
8th Aug 2018, 8:40 pm | #5 |
Excellent, how on earth did you find that, Lawrence?
I think I need to find some technical information to stand any chance of making it work, though. The motor has a data plate on it, but it's up against an internal wall so I can't read it. I have an old Henry's Radio catalogue, I'll see if it's in there. Many thanks, Andy |
8th Aug 2018, 9:02 pm | #6 |
Googled "sound recorder type 4185" that returned a hit to the link below:
https://www.iwm.org.uk/collections/item/object/30000147 That had the same A.M Ref. and also a reference to Boosey & Hawkes , Grace's Guide for Boosey & Hawkes gave the advert for a wire recorder that looked very similar. Lawrence. |
8th Aug 2018, 9:02 pm | #7 |
I've just found gingpeakin's earlier thread on his recorder, including the circuit he drew out -
https://vintage-radio.net/forum/showthread.php?t=68894. Has anyone got one working? |
8th Aug 2018, 9:31 pm | #8 |
This looks like the airborne version i.e. record only.
There is a working version of the more common ground version (playback and record) in the Henlow signal museum - it is almost hypnotic when in action. I'm sure they would love a aircraft version if one is looking for a good home. TYJ
"If we are not going to make things, what are we going to do?" Fred Dibnah |
9th Aug 2018, 12:14 am | #9 |
What was it used for on the aircraft.
Is it a CVR?
-- Graham. G3ZVT |
9th Aug 2018, 8:59 am | #10 |
From the advertisement found by Lawrence it sounds to me that it was intended to record the pilot's voice during test-flying rather than as a data recorder. But I guess it could be used for both if the data being logged was encoded into a suitable format compatible with the audio spectrum.
Andy |
9th Aug 2018, 9:26 am | #11 |
Some further information posted on the Aviation Forum.
Andy |
9th Aug 2018, 4:32 pm | #12 |
Looks like it was an early "Black Box"
Mike |
9th Aug 2018, 5:26 pm | #13 |
I wouldn't describe it as an early 'Black Box'. The purpose of the black box (which is usually bright orange!), Crash Recorder or Accident Data Recorder, is to record various flight parameters of the aircraft, and may also include the pilot's voice, for accident investigation purposes, whereas this unit is to allow a test pilot to record what is happening during a test flight verbally rather than on a note-pad on his knee.
Obviously, though, there is considerable overlap between these two functions, without a clear distinction. |
13th Aug 2018, 2:55 pm | #14 |
I had a short-term job at the B&H factory (Sonorous Works) in Edgware in 1973. I remember being interested to be told by one of the older workers that they had made Wirek recorders during WW2. There were still a few drawings of parts of them in the files. Sadly all long gone now, a housing estate of course...
13th Aug 2018, 4:44 pm | #15 |
Yes modern day black boxes are orange, and I suspect they record everything digitally. But the name black box originated from somewhere, and in the early days there would be no way of recording anything other than by the pilot explaining what was happening in the cockpit. As this box is black in colour, could this be an actual "black box" flight recorder.
Mike |
13th Aug 2018, 6:32 pm | #16 |
Flight recorders were made bright and stripy once they became standard fit in passenger planes to make them easier to find after something has gone wrong.
14th Aug 2018, 11:31 am | #17 |
I was told yonks ago (and I suspect that it's a little fanciful like so much of the black humour in the aviation world, I'd like to think that there's an element of truth in it though) that the first FDR, used in test-piloted prototypes, was a soft fire-brick cradle-mounted beside the pilot with a set of pre-loaded punches above it designated "airframe", "engine", "controls" etc., the idea being that the pilot would have opportunity and presence of mind to thump the appropriate plunger in the event of unsurvivable incident.
