Old 12th Apr 2018, 11:57 am   #1
Argus25
No Longer a Member
Default IBM 5155 power supply
I have just completed a 21 page document on this switch-mode supply from the early 1980's. IBM did not publish data on it.
http://worldphaco.com/uploads/The_IB...WER_SUPPLY.pdf
It contains a range of different circuit innovations including surge limiters that use a PUT, current detectors with a current transformer, modulated base drive for the switching transistors with current feedback to improve efficiency.
One idea allows the use of a transformer with a 115V primary to be run from a 230V supply (for the 115/230V universal power input select circuit). It is a good method to synthesize what amounts to a low Z reference point that splits the incoming 230V mains in two. This idea would be suitable for running many small transformers in small 115V appliances from 230V without the need of a stepdown transformer and better than a series resistor or reactance as the method relatively independent of the load. It requires a bridge rectifier and two high value 200v electrolytic caps.
Argus25 is offline
Old 12th Apr 2018, 8:36 pm   #2
Al (astral highway)
Al (astral highway)'s Avatar
Default Re: IBM 5155 power supply
Hey Hugo,
That's another monumentally detailed piece of investigation, primary research and documentation. Thanks for making this contribution. I had never thought that viable, robust SMPS existed as early as this and it is high-powered and quite intricately thought out.
I looked at the overcurrent sense arrangements with particular interest. Really interesting to see the two conditions you describe:
*overcurrent AND
*final Vout, supply, > specified limits.
That's really ingenious. I also note the inrush limiting arrangement. I've never seen or heard of a programmable unijunction transistor before - really interesting to see an unfamiliar variant of a very useful circuit.
Cheers!
Al
