Reply
Old 11th May 2010, 6:49 pm   #561
SPCh
SPCh's Avatar
Default Re: AVO Multimeter survey
Olly,
Welcome to the Forum, and thanks for your input.
I would expect the xxxx to be in the region of 2700;
if you're bashful, perhaps you could send me a confirmation, or rebuttal, by PM.
Many thanks
SPCh
SPCh is offline   Reply With Quote
Old 13th May 2010, 7:52 pm   #562
olly 476
3606-a-248
olly 476 is offline   Reply With Quote
Old 18th May 2010, 8:11 pm   #563
peterxxx
My contribution
Model 7 71147-A-41242
Model 8 Mk 2 2927 C 663D
Model 8 Mk 3 19343 665
Model 8 Mk 5 5270-046 CH6
I am sure the CH6 is not part of the number, anyone know what it means?
Peter
peterxxx is offline   Reply With Quote
Old 22nd May 2010, 10:32 pm   #564
Leonie_C
Evening All,
I Inherited 3 Avos from my late father a few years back, 2 mk 8s (I think) although they're slightly different from each other, and 1 multiminor.
Avo mk8 SNo: 17530.369 & Sno: 18785, (this ones marked "test set multirange No.1 High Sensitivity" on the case)
Both have hammerite metal enclosures, and came from the now non-existent REME Civilian workshops in Strensall (York), where my Dad was an elec. engineer.
Multiminor: Sno:55024
I'm a mechanical eng myself *shame* so they don't get used, but it'd be nice to know a bit more about them.
Leonie_C is offline   Reply With Quote
Old 24th May 2010, 12:36 pm   #565
threeseven
threeseven's Avatar
model 40 , s'no 47133 , 40/11/7A
Complete with leather case , small spanner (?) and leads. Need a new red terminal cap and a 1 black terminal plug for a PF socket , if anyone can help ?
threeseven is offline   Reply With Quote
Old 24th May 2010, 5:02 pm   #566
gezza123
gezza123's Avatar
HI: Just going through the forum .
My Universal Avometer Model 8
serial No. 168655-c-564
part No. 13574-3.a
No. on case top 6625-99-943-1532.
with leather case/Eht tv adapter/leads.
Good condition still in use.
hope this helps.
Gezza.
gezza123 is offline   Reply With Quote
Old 25th May 2010, 3:53 pm   #567
Ben-G4BXD
8 2146C4638 working fine
8X 69924C158 scrapped as u/s
7 number unknown (Repair question moved to here)
12 5132-7-75 working fine
Ben.
Last edited by Darren-UK; 25th May 2010 at 6:35 pm. Reason: Repair issue split to new thread.
Ben-G4BXD is offline   Reply With Quote
Old 27th May 2010, 1:06 pm   #568
hilitevr
Just aquired an AVO model 8 Mk 6 s/n 1395 M90218 Date 9/85
Very good condition.
Trevor
hilitevr is offline   Reply With Quote
Old 5th Jun 2010, 4:30 pm   #569
PJL
Model 8 Mk II 135899 C 362 shunt needed repair and the leads have melted but has a very nice leather case.
PJL is offline   Reply With Quote
Old 8th Jun 2010, 4:54 pm   #570
Bryan M
Bryan M's Avatar
My model 8 mark ? has the scale marked 'Test Set Multirange No.1 High Sensitivity 6625-99-105-7050' and ser. no. 2833-967. It sits in a metal case sprayed bronze metallic.
My model 7 has serial no. 71047-37524.
Bryan
Bryan M is offline   Reply With Quote
Old 8th Jun 2010, 7:27 pm   #571
sentinel040
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
My long suffering (about 33 years) 8X (Panclimatic), with metal outer rear case and green carrying case (handle now getting a bit tatty) is No. 3130-C-7637. It had a replacement rectifier about 31 years ago after starting to read low, other than that it keeps taking whatever I throw at it.....
I also have a back-up (and little used) 8 mark 5, bearing serial number "40501 8V/11/76" on a sticker on the side of the case. It has a leather case with self destructing stitching; there seems to have been a quality control problem here!
Regards
Ian
sentinel040 is offline   Reply With Quote
Old 8th Jun 2010, 9:49 pm   #572
SPCh
SPCh's Avatar
Thanks for keeping them coming ....
Bryan,
your Model 8 Mk ? is a specific NATO version (designated TS1 not Model 8).
It's actually a Model 8 Mk II, modified for a 3-10-30 rather than a 2.5-10-25 range sequence, and with the extreme reistance ranges (L.R and INS) excluded.
They also dropped decibels from the scale (although with a 3-10-30 range sequence it might have been appropriate to keep it).
Sentinel,
if the quality problems had only reached the stitching ....
With a little bit of the original MacAdie ethos, the Model 5 would have been an excellent meter, but this was the Thorn environment : go for new unproven technology to save cost, and ... pay the price !
Old 9th Jun 2010, 12:41 pm   #573
Woody-troon
Hi just been given an Avo 8, rescued from a skip in very good condition externally, have not put batteries in it yet (will have to look at option to do that as no manual).
Its serial number is 47869-c-556
Can you tell me what model it is, would be much appreciated.
Woody-troon is offline   Reply With Quote
Old 9th Jun 2010, 10:12 pm   #574
SPCh
SPCh's Avatar
Yes, it's a fairly early Model 8 Mark II.
Has it got a 500 volt DC range, or just a gap between the 250 & 1000 volt switch positions ?
Old 16th Jun 2010, 1:58 am   #575
jamesinnewcastl
jamesinnewcastl's Avatar
Mmmmmmmm
Finally acquired an AVO EA 113 that works, well it has some bizzare behaviour but that is apparently normal! Serial Number is 5990.
Not everyones cup of tea but I've wanted one for about 35 years!
I will get my other 2 faulty ones going though (already logged here)! Just a matter of time really!
James
jamesinnewcastl is offline   Reply With Quote
Old 16th Jun 2010, 4:31 pm   #576
Derminator
Hi. Picked this one up at a car boot at the weekend. Model 8 mkII s/n 5XXXX-C-157.
Derminator is offline   Reply With Quote
Old 21st Jun 2010, 1:03 am   #577
neon indicator
Given to me a couple of years ago
AVO model 9 MkIV Serial 22115 94/11/70
Is the last part a crazy date code?
Handy for the anodes of the 6146s on my FT101ZD MKIII
neon indicator is offline   Reply With Quote
Old 22nd Jun 2010, 4:42 pm   #578
andytate
AVOs still working condition:-
Avo 7 7647 35760
Avo 7 7943 11077
Avo 7 Mk2 889728 A 362
Avo 8 IV 24327 84/12/70 Metal back 0 25 scale
Avo 8 V 14376 8V/4/74 Serial sticker very worn
Possibly 11376 easier when number on dial plate
andytate is offline   Reply With Quote
Old 22nd Jun 2010, 11:06 pm   #579
andytate
Plus the AVO I use at home - still with its original cardboard box from ITT Distributors
AVO 8 Mk V 04117 8V/7/77
Old 23rd Jun 2010, 10:49 pm   #580
SPCh
SPCh's Avatar
Yes, Neon; not so crazy, really
94/ = Model 9 Mk IV and
11/70 = November 1970
Reply
