Old 14th Sep 2021, 11:56 pm   #1
MercuryFire
Default Tascam Tape Issue
I recently picked a second hand Tascam 122 MKII Tape unit. The person who owned it said he hadn't been used in a long while.
It has a problem with Play/FF function. I can rewind a tape with no issue, but pressing play does nothing. When I press FF it makes a slight noise for about few seconds (like it wants to move) but also does nothing. Does anybody know what is the issue and is it something that can it be fixed? And if so, what is required/how etc?
At times, when I do press fast forward and rewind, they all work normally. But when I press play, I can hear something, like a noise that wants to start playing but after 2-3 seconds it stops. Sometimes after I have rewinded, if I press play it will actually start to play but then after about 10 seconds it just going fast forward at speed!
MercuryFire is offline
Old 18th Sep 2021, 7:48 pm   #2
Linnovice
Default Re: Tascam Tape Issue
Hi and welcome.
Have you got any lights on next to the transport keys?
Small Scotch, New Aids and Happy Ears
Linnovice is offline
Old 19th Sep 2021, 5:35 am   #3
MercuryFire
Yes, all lights are on.
Old 19th Sep 2021, 5:06 pm   #4
Linnovice
Right, that’s not good. It sounds like one of the transport gears is broken. Usually ‘C’ gear in the manual. It’s a common fault and easily rectified. The transport will have to taken out and partially stripped. The gears separated, cleaned, broken gear replaced, reassembled, lubricated and mounted back in the machine again. It’s caused by the grease used in the transport train going hard and seizing up the gears.
There is a lot of info on the internet. Just Google Tascam 122mkiii transport problems. If you’re fairly handy with screwdrivers and small mechanical repairs it’s pretty easy.
Good luck ��
Old 19th Sep 2021, 11:00 pm   #5
TIMTAPE
This is a MKII, not a MKIII.
TIMTAPE is offline
Old 20th Sep 2021, 5:56 pm   #6
Linnovice
Whoops, apologies. I misread the OP.
Old 22nd Sep 2021, 8:20 am   #7
Ted Kendall
What is the state of the reel idler tyres?
Ted Kendall is offline
Old 23rd Sep 2021, 7:45 am   #8
MercuryFire
Being a newbie, I wouldn't know what I am supposed to be looking for, can you help direct me what I need to check please?
I have attached photo, not sure if this helps...
Old 23rd Sep 2021, 12:05 pm   #9
Ted Kendall
The spooling hubs are driven by idlers - two in the Mark II, I think - and the tyres on these can split. They sit just behind the metal plate through which the hubs protrude.
Old 23rd Sep 2021, 11:45 pm   #10
jamesperrett
If the 122 is anything like the 112 that I fixed a few months ago then the mechanism is fairly easy to remove - just 4 or 5 screws if I remember correctly. You will almost certainly need to remove the mechanism in order to get at the idlers.
jamesperrett is offline
