Old 10th Apr 2021, 10:23 pm   #1541
ortek_service
ortek_service's Avatar
Default Re: Non-working Commodore PET 3016
Originally Posted by SiriusHardware View Post
Which unfortunately is open-Collector
I missed that little detail
Last time we ran into this problem the OP didn't have a scope so we never got as far as trying to analyse the problem, we just went for a chip change which fortunately did solve it.
I did have to check the datasheet, as I had a feeling it would be when I saw the outputs were all inverted (But forgot it was TTL so now corrected Drain to Collector!)
However, if it's inputs are changing correctly then I can't see there could be anything else to explain the incrementing by 2 fault symptoms
- as I did check that it wasn't just 2 of the 10 row scan lines that could be shorted together (Although you could be really unlucky at have 5 shorts between adjacent pairs)
But we do know how fond this PET (Although technically a CBM model?) seems to be of devouring TTL IC's.......
ortek_service is offline
Old 10th Apr 2021, 11:41 pm   #1542
ScottishColin
I have ordered a new 74LS145 which I guess will arrive Tuesday.
I will resolder the broken trace tomorrow and retest continuity.
I am assuming the 74LS145 is UC9 - is that right?
Colin.
ScottishColin is online now
Old 10th Apr 2021, 11:50 pm   #1543
SiriusHardware
Indeed so.
SiriusHardware is online now
Old 10th Apr 2021, 11:51 pm   #1544
ScottishColin
Thanks.
Feel free to take tomorrow off...
Colin.
Indeed so.
Old 10th Apr 2021, 11:56 pm   #1545
ortek_service
There's still a chance that the UC9 (74LS145) is actually OK, and you could confirm this if you want before changing it / waiting for it to arrive, if order has been completed - See below, from previous post, for what to check:
Originally Posted by ortek_service View Post
So it does rather look like an issue with bit0 of the BCD code on the 74LS145 is not working. And there's still a chance of a bad connection to the 6520 PIA (or even that itself to be a 'bit' dodgy!)
Probing the 'KEYA' line at:
UC9(74LS145) Pin 15 ('A' input) /
UC7(6520) Pin 2 (PA0)
should hopefully see if that is switching OK at both ends and therefore working OK at least - before suspecting/condemning the 74LS145
Old 11th Apr 2021, 12:00 am   #1546
Mark1960
Colin.
Check for activity on the A input first, UC9-15.
Would be a shame to wait until Tuesday to find it was the lack of input that caused the problem.
Mark1960 is offline
Old 11th Apr 2021, 12:22 am   #1547
ScottishColin
Does there need to be keyboard activity during these tests?
Colin.
Expanding on Julie's thoughts in #1535 I suggest this, only when that track fault has been fixed.
Scope UC7 pins 2, 3, 4, 5
Scope UC9 pins 15, 14, 13, 12 - should have the same waveforms on as the above.
Then scope the following pairs of pins together, always with the first pin of each pair on the upper trace.
UC9 pins
1 and 2
2 and 3
3 and 4
4 and 5
5 and 6
6 and 7
7 and 8
8 and 9
9 and 10
Old 11th Apr 2021, 1:37 am   #1548
ortek_service
No pressing of keys is required, as just need to test the control of the keyboard rows-scanning outputs, that is done by the Kernal ROM
- So need that one in place, and it booted into BASIC's normal operation.
However, you only really need to probe 1 or 2 pins, as it's been possible from the fault symptoms to narrow this down to the least-significant bit of the 4 BCD lines into the UC9 74LS145.
So only really need to (as suggested in the 2 posts prior to the previous one):
Probe the 'KEYA' line at: UC9 (74LS145) Pin 15 ('A' input)
& (particularly if no activity there) also: UC7 (6520) Pin 2 (PA0)
Old 11th Apr 2021, 8:51 am   #1549
SiriusHardware
I'd better point out that these measurements, as Owen pointed out, won't work unless some resistors are added - so don't bother with those at the moment.
Code:
UC9 pins
1 and 2
2 and 3
3 and 4
4 and 5
5 and 6
6 and 7
7 and 8
8 and 9
9 and 10
Old 11th Apr 2021, 9:11 am   #1550
julie_m
If you get desperate to do those measurements, each of the pins of UC9 under test will need one end of a 10K resistor connected to it; with the other end connected to UC9 pin 16 or any other convenient +5V pin.
Also, I think UC9 pin 8 is actually 0V; so the last three tests probably should be comparing pins 7 and 9, pins 9 and 10 and pins 10 and 11 respectively.
julie_m is offline
Old 11th Apr 2021, 1:06 pm   #1551
ScottishColin
OK - that's done and continuity is restored. Thanks to all who suggested it.
I need to steal some clear lacquer now to cover it over.
Colin.
Originally Posted by Mark1960 View Post
Are there good ways to deal with these kind of issues?
I think for that trace you can scrape about 3mm of track clear of solder resist at each end of the break and use a single strand from a multistrand cable to link the two ends. Keep the solder to a minimum and it should still allow the keyboard to be reassembled.
Edit: Is three a record for cross posting?
Old 11th Apr 2021, 5:23 pm   #1552
julie_m
Most pound stores will have clear nail polish in their cosmetics sections. (Bloke tip: it probably will be near one end or the other, may be labelled "base coat" or "top coat" and probably will have a white lid.)
julie_m is offline
Old 11th Apr 2021, 5:34 pm   #1553
ScottishColin
Two screenshots attached.
Colin.
Name:	UC9 pin 15 - 20210411.jpg
ID:	231493   Click image for larger version
Name:	UC7 pin 2 - 20210411.jpg
Old 11th Apr 2021, 5:35 pm   #1554
ScottishColin
I managed to borrow some from my better half ta. Tip noted though.
Colin.
Old 11th Apr 2021, 5:37 pm   #1555
ScottishColin
Hopefully this doesn't make any difference - the ShiftLock key has been desoldered (it's a different type of key to all the others) and the two wires are just floating apart from each other and not touching anything right now.
Colin.
Old 11th Apr 2021, 5:38 pm   #1556
ScottishColin
I've scoped UC9/15 and UC7/2 as per a later suggestion.
Would it still be useful for me to test the other UC7 (3, 4 and 5) and UC9 (12, 13 and 14) pins?
Colin.
UC9 pins
1 and 2
2 and 3
3 and 4
4 and 5
5 and 6
6 and 7
7 and 8
8 and 9
9 and 10
Old 11th Apr 2021, 5:52 pm   #1557
SiriusHardware
Yes, if you haven't already. The one we think there could be a problem with is UC7 pin 2 - UC9 pin 15 (Same signal line, different ICs, just to make sure the signal is present at both ends).
Disregard anything I said about UC9 pins 1 through 10, I was obviously having a bad day yesterday. As long as we have the expected signal on UC7 pin 2 / UC9 pin 15, the 74LS145 remains the prime suspect.
Old 11th Apr 2021, 6:07 pm   #1558
ScottishColin
Here's UC9/15 and UC7/2 compared.
Is it worth having the other UC9/UC7 pins as a comparison (ie both on the same screen)?
Colin.
Name:	UC9 pin 15 yellow UC7 pin 2 green - 20210411.jpg
Old 11th Apr 2021, 6:28 pm   #1559
julie_m
If I'm reading it right, that pin is going cleanly low five times in a row for about 125µs (?) each, about every 17ms; which is exactly what I would expect to see from the sequence 0000-0001-0010-0011-0100-0101-0110-0111-1000-1001 being written to pins 12-15 of UC9.
I'd expect pin 14 to stay low most of the time and periodically make two high-going pulses of 250µs (or at any rate twice whatever the original duration was, if I misread it); pin 13 to stay low most of the time with high-going pulses of 500µs; and pin 12 to stay high most of the time with periodic low-going pulses of 1ms. If you keep pin 15 connected at the same time as the other pin under test, it should be possible to see the relationship between the bits.
This suggests UC9 is getting the right inputs, which is a relief as it means UC7 is probably good. Probing the outputs of UC9 would need resistors adding as discussed above, but I'd happily condemn it on the evidence above alone. Still, if you are feeling sufficiently curious (or masochistic ), each of pins 1-11 (except 8) should show a single low-going pulse of 125µs every 17ms, lined up under one of the ten steps of the pin 15 sequence, if UC9 were good.
julie_m is offline
Old 11th Apr 2021, 6:54 pm   #1560
ScottishColin
Attached is UC9/15 compared to 14,13 and 12 - is that what you're after?
Colin.
Name:	UC9 pin 15 yellow pin 14 green - 20210411.jpg
ID:	231503   Click image for larger version
Name:	UC9 pin 15 yellow pin 13 green - 20210411.jpg
ID:	231504   Click image for larger version
Name:	UC9 pin 15 yellow pin 12 green - 20210411.jpg
