Old 11th Jun 2019, 12:58 pm   #21
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: AD28 batteries no longer available? Substitutes?
Originally Posted by mark_in_manc View Post
... 18650 [Lithium rechargeable cells] about 4v, would be close enough. 3 in parallel would last a good while - and they're free in a dead laptop battery near you
At the risk of going too far OT, I have indeed re-purposed several such cells and they can be excellent in high drain applications when properly managed. However they can pack a 35 amp punch, so need to be fused, and the charging regimen is critical to avoid danger. I wouldn’t personally use them in a low-drain application, although their self-discharge rate is very low.
Phil
Phil G4SPZ is offline
Old 11th Jun 2019, 9:30 pm   #22
davyrocket2
Yes I realized I made a mistake. What meant to say was if I purchased two lantern batteries can I use three of the cells to replace the dead ones in the AD28 original packaging? One is still very bright after one year, but only gets occasional use and is kept in good dry conditions.
davyrocket2 is offline
Old 11th Jun 2019, 10:07 pm   #23
af024
Will 3 x C-cells fit?
Now where on earth did I remove that from?
af024 is online now
Old 11th Jun 2019, 11:57 pm   #24
martin.m
martin.m's Avatar
Poppydog, is your radio a Perdio Town and Country? I have one of these and simply use a six pack AA battery holder filled with alkaline cells. Home Bargains sell a 20 pack of JCB brand AAs for £3. The trouble with rechargable cells is that they only give 1.2 volts. As others have suggested, it is a good idea to include a fuse.
Regards
Martin
martin.m is offline
Old 12th Jun 2019, 8:38 am   #25
Paul JD
Yes, that's what I have used. Made a small wooden box of the correct size and covered it with a scan of the battery case that I found on the internet and printed onto card.
Paul JD is offline
Old 12th Jun 2019, 8:55 am   #26
poppydog
Can you fit the back cover on properly with those in there?
poppydog is offline
Old 12th Jun 2019, 9:15 am   #27
Paul JD
Yes (see the one in the radio which in best Blue Peter style is one I made earlier!)
Paul JD is offline
Old 12th Jun 2019, 11:30 am   #28
ThePillenwerfer
ThePillenwerfer's Avatar
Would you be prepared to add that scan to the sticky at the top of this section? It seems to be quite a rare one that I haven't been able to find. I don't need it personally as I've fitted U2 holders in my Bardics but other people may well if pusser batteries can't be found.
ThePillenwerfer is offline
Old 12th Jun 2019, 12:12 pm   #29
Paul JD
Done
Paul JD is offline
Old 12th Jun 2019, 12:47 pm   #30
poppydog
Looking good
Regards Poppydog
poppydog is offline
Old 12th Jun 2019, 4:52 pm   #31
Herald1360
Herald1360's Avatar
"Pusser"? Is that a variation of "pukka"?
Dr. G simply talks about rum!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 12th Jun 2019, 5:21 pm   #32
Station X
Station X's Avatar
I'm sure Paul JD meant "pusser", it's the way "purser" was pronounced in The Royal Navy.
Pusser's rum, like everything issued by the pusser was 100% service original.
Back on topic please.
Graham. Forum Moderator
Station X is online now
Old 12th Jun 2019, 7:08 pm   #33
Paul JD
Wasn't me that said it!
Paul JD is offline
Old 12th Jun 2019, 8:23 pm   #34
Station X
Station X's Avatar
Quite right it was ThePillenwerfer.
I was confused by the preceding post being quoted in full
Old 13th Jun 2019, 9:09 am   #35
Herald1360
Herald1360's Avatar
So it's a navy version of pukka (which presumably is an (indian) army term)?
....__________
