Old 11th Jun 2019, 7:58 pm   #21
julie_m
Default Re: Pioneer record deck
The coils in the cartridge have continuity (post 16) and the amplifier is working (post 5); therefore, loss of magnetism in the cartridge seems to be the only plausible failure mode.
If you hold the cartridge near an Orienteering compass (borrow one from the nearest Boy Scout if needs be!), can you get the needle to deflect away from North? You are looking for a movement away from the cartridge -- plain, unmagenetised steel will always attract a compass needle, but a magnet will attract one end and repel the other.
It's also just about vaguely possible for the stylus cantilever not to be connecting with the armature plate. (I've actually had something similar happen with a ceramic cartridge: the plastic fork that connects the cantilever to the sensing elements was missing. And the record player was my birthday present.)
At any rate, if a new stylus did not fix it, then the cartridge is the only thing left now that can be faulty. Might be worth an autopsy, even!
julie_m is offline
Old 12th Jun 2019, 7:40 am   #22
Edward Huggins
I'm rather surprised that it was thought that the fitting a new stylus to a cartridge that was giving no mV output would solve this problem?
Edward.
Edward Huggins is offline
Old 12th Jun 2019, 9:20 am   #23
Nickthedentist
Nickthedentist's Avatar
So am I, Edward, but see post 7
I will hunt down the cartridge I promised tomorrow if possible.
Nick.
Nickthedentist is offline
Old 12th Jun 2019, 6:47 pm   #24
112stereo
No luck with the new stylus, so conclude the cartridge is faulty.
Looking carefully under a magnifying glass where the stylus feed connects the hole is Damaged, but with not having anything to compare it with I am guessing this is the issue.
112stereo is offline
Old 18th Jun 2019, 10:47 am   #25
Nickthedentist
OK here's the cartidge I found. It looks better in the flesh! Stylus looks intact but untested so no guarantees.
If it fixes your turntable, then no charge, just keep it and use it. If not, I'll have it back for my "stores" please
PM me your address if you'd still like it.
Nick.
ID:	185289   Click image for larger version
ID:	185290   Click image for larger version
ID:	185291   Click image for larger version
Old 18th Jun 2019, 4:45 pm   #26
Nickthedentist
Sent this afternoon
Old 24th Jun 2019, 11:56 am   #27
Nickthedentist
Did the cartridge ever arrive?
Nick.
Old 26th Jun 2019, 9:52 am   #28
Nickthedentist
Roger tells me that it did indeed arrive, and that it did the trick (surprisingly in a way!).
N.
