Old 9th Jun 2019, 4:13 am   #221
electronicskip
electronicskip's Avatar
Default Re: What vintage equipment did you actually use today?
Used my newly resurrected Philips 2020 machine today .
Next on the list to get going is another Philips 1702 unit.
electronicskip is offline
Old 9th Jun 2019, 1:20 pm   #222
Refugee
Refugee's Avatar
I have been brightening up this Sunday morning listening to Chas and Dave on home made speakers driven by a pair of trusty Mullard LP1162 modules that were found in some audio stuff I acquired in the 1980s that included valve amps that I still also use regularly.
Refugee is offline
Old 9th Jun 2019, 2:29 pm   #223
PaulR
PaulR's Avatar
What is a Philips 2020? I googled it and came across a blender and an "all in one body groomer that trims and shaves all body zones exclusively for men"!
Paul
PaulR is offline
Old 9th Jun 2019, 2:57 pm   #224
ajgriff
ajgriff's Avatar
I'm told that male grooming is really catching on these days but what would I know. The VR2020 was streets ahead of its time too when compared to its VHS and Betamax counterparts.
Alan
ajgriff is offline
Old 9th Jun 2019, 6:04 pm   #225
Graham G3ZVT
Graham G3ZVT's Avatar
The general name for this format is "Video 2000" and it was indeed streets ahead of Betamax and VHS, but the world wasn't ready for yet another format.
The tape was 1/2 inch wide but the format was 1/4 inch so you could flip it over and recorded on the other side like a Compact Cassette.
the heads in the drum were mounted on piezo crystal mountings and the machine was able to correct tracking errors dynamically as each head traversed the track.
I can't remember if a Hi-Fi alternative to linear audio track was implemented but I'm sure it would have been, had the format survived.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 9th Jun 2019, 6:10 pm   #226
PaulR
PaulR's Avatar
Interesting, thanks for the information.
Paul
PaulR is offline
Old 9th Jun 2019, 6:43 pm   #227
Martin G7MRV
Had my Clansman PRC320 in use today bagging a few special event stations during my lunch break.
I got food in ma belly and a license for ma telly
My Blog - http://g7mrv.blogspot.com
Martin G7MRV is offline
Old 9th Jun 2019, 8:07 pm   #228
Lancs Lad
Lancs Lad's Avatar
When you wrote the word 'bagging', Martin, I thought for a moment you were talking about your actual lunch!
Here in Lancashire, 'bagging' is what we call a packed lunch.
"It's baggin' time!", is the phrase often heard across the county (we don't pronounce the 'ing', of course!)
I believe it's called 'snap' in Yorkshire.
Best Regards,
Peter.
Lancs Lad is offline
Old 11th Jun 2019, 9:28 am   #229
So, do hungry Yorkshiremen get a bit snappy
Herald1360 is offline
Old 14th Nov 2019, 9:59 pm   #230
mark2collection
mark2collection's Avatar
Currently listening to my Philco 333, a bit of Jazz on a cold/wet evening.
Lights down low, incense on the go ... contemplating a tumbler and a drop of something warming, trouble is, it's a 'school' night, maybe a mug of hot chocolate instead.
Mark
Slowly turning the 'to-do', into 'ta-dah'
mark2collection is offline
Old 14th Nov 2019, 10:49 pm   #231
ITAM805
ITAM805's Avatar
My 1965 Vox AC30 TB, demoed it and after 40 some years of ownership, sold it
ITAM805 is offline
Old 14th Nov 2019, 10:58 pm   #232
M0TGX Terry
Today I used the Murphy A122c which I bought at Golborne to listen to a mixture of BBC radio 4 on long wave and 1940's music via a Minimod pantry transmitter.
Terry the Morganist
M0TGX Terry is offline
Old 14th Nov 2019, 11:52 pm   #233
suebutcher
suebutcher's Avatar
Nearly every day, a 1975 Teasmade 855 to wake me up and make me tea, and a 1961 Ultra TR81 to play me music to wake my brain up as well. I've got plenty of other radios, but the Ultra is the best one for classical FM; the internal speaker is small, but it's a Celestion.
The Waves That Rule Britannia
suebutcher is offline
Old 15th Nov 2019, 12:06 am   #234
KeithsTV
KeithsTV's Avatar
I have a 60s Anglepoise lamp that I now use when I'm working on the bench I acquired when a building where I worked was about to be demolished. I used it for a few years before consigning it to the garage. Having seen how much they go for I had another look at it but unfortunately the cable had rotted. I found a source for a replacement cable that looked the part fitted it then discovered that the finely balanced mechanism is not suited to LED light bulbs as they are too heavy and the lamp shade cannot be held in the required position. However the filament types of LED lamps are much lighter and have a similar weight to an incandescent bulb and fitting one of these has allowed me to position it where I want with the advantage of consuming about 6W.
Keith
KeithsTV is offline
Old 15th Nov 2019, 1:03 am   #235
gingpeakin
Sadly I scrapped a perfectly working VR2020 machine some years ago. Ho Hum.
Every day I listen to my KB FB10 (a nice green one) in my kitchen. It was a leaving present from my chums in BBC OBs and is a focal point in my kitchen.
I also use an HP 3450B and an HP 8640B along with a dual 0-30V 5A bench power supply I made in 1986 almost daily. I used to have a Tek 7603 with the usual plugins in regular use until I forked out for a lovely Rhode+Schwarz (was Hameg) HMO3004 a couple of years ago.
Ging
gingpeakin is online now
Old 15th Nov 2019, 1:06 am   #236
Phil G4SPZ
Phil G4SPZ's Avatar
Tonight I used my 1955 Avo Mk III valve tester to test a batch of 1.4 volt battery valves (which I’d been meaning to do for ages). Some of the valves were good, but the majority were low gain and had to be binned.
The valve tester will be going to a new owner tomorrow as I hardly use it these days. I can still fall back on my trusty 1946 Weston Tube Checker which, whilst nowhere near as good as the Avo, will check most valves and takes up a lot less space.
Phil
Phil G4SPZ is offline
Old 15th Nov 2019, 2:29 am   #237
MurphyNut
MurphyNut's Avatar
Nice, you don't see the console version of the A122 much these days.
Clive
MurphyNut is offline
Old 15th Nov 2019, 8:47 am   #238
PaulR
PaulR's Avatar
I hadn't really thought of it until now but I suppose our 1980 Creda Cavalier cooker which is in daily use and has been for nearly 40 years counts as vintage in many people's eyes. The Hoover 652 would count as well, although I can't help wishing it was a 652A with the switch within the body so it does not knock the paintwork around so much.
Paul
PaulR is offline
Old 15th Nov 2019, 9:43 am   #239
MikeCross
Ferrograph series 4 to Ferrograph series 5. Copy/editing old tapes.
MikeCross is offline
Old 15th Nov 2019, 9:58 am   #240
electronicskip
A quick bash on my Atari 2600 system with Riddle of the sphinx.
Oh I've had that for years dear!!
