18th May 2020, 7:55 pm | #41 |
Re: Bill's Quad woes cont.
Sorry that should be R19, not R22.
Bill. |
20th May 2020, 5:42 pm | #42 |
Quick update: got the last resistors in and everything works, but still low volume on pick up. Will start on Capacitor replacement soon hopefully, thanks for sticking with me!
Bill. |
20th May 2020, 11:44 pm | #43 |
Valve circuits are usually quite tolerant of resistor value changes although in a hi-fi amp it is worth getting them right. It's the capacitors that are more likely to cause major performance problems.
21st May 2020, 1:04 am | #44 |
I'm a bit surprised at you going for the resistors first. I absolutely agree that the problem is far more likely to be caused by the capacitors - famous last words!
21st May 2020, 8:57 am | #45 |
Agree with Post #44. If you're cranking up the volume of the QC2 to nigh on 50% the output should be ear-splitting. The QC2 is basically half a Quad22 and on my Quad22 a comfortable listening level is about 2 on the volume cursor, using a moving magnet cartridge. I should think replacing the caps should make a marked improvement.
21st May 2020, 11:31 am | #46 |
I agree with previous post. I have my Quad 22 on 2 to 3 position. I don't think I have ever used it on 4 or 5, let alone 6 . I think the speakers and ears would suffer at that level !!
Mike. |
21st May 2020, 12:26 pm | #47 |
Thanks guys, half way through the caps right now, I will remember to start there with my next project, whatever that may be. Showing I'm a bit green at this I guess!
Cheers from Bill. |
21st May 2020, 1:43 pm | #48 |
Cue Jaws' 'shark moving in' sound effect!! Change them, just change them.
A digital radio is the latest thing, but a vintage wireless is forever.. Last edited by stevehertz; 21st May 2020 at 2:06 pm. |
21st May 2020, 4:40 pm | #49 |
Changed and working now. I tested both EF86 in the quad, and whatever was going on destroyed the one and impaired the other. So volume is back to no. 5 on the control. Will order another EF86 and see if we get anywhere with that. Suggestions welcome if there is something I have missed.
Cheers from Bill. |
21st May 2020, 4:50 pm | #50 |
Now we know the components are good, you need to measure the voltages on the valves (anode, cathode, grid 1 and grid 2) and post the results here. That will tell us if they are worn out. It may not be the EF86.
21st May 2020, 7:09 pm | #51 |
Hi, EF86 measurements
Anode Pin 6: 83.0 VDC Cathode pin 3: 1.54 VDC Grid 1 Pin 9: 0 VDC Grid 2 Pin 1: 70.1 VDC Just to be sure I did it right, I measured all to chassis ground, and measured on the valve base pins. Cheers from Bill. |
21st May 2020, 8:22 pm | #52 |
The EF86 voltages look good so it is probably OK. Now measure the cathode, grid and anode of both halves of the ECC83.
21st May 2020, 8:47 pm | #53 |
Ecc83
A1 Pin 1: 3.2mVDC A Pin 6: 3.1mVDC K1 Pin 3: 2.8mVDC K Pin 8: 0 G1 Pin 2: 3 VDC G Pin 7: 1.24 VDC Cheers from Bill. |
21st May 2020, 9:17 pm | #54 |
I think you must have made a mistake with your voltage measurements as it would not be working with these values. Have another go.
21st May 2020, 9:18 pm | #55 |
Yeah, it looks weird, I will retest.
Bill. |
21st May 2020, 9:42 pm | #56 |
Silly mistake; transposed the pins back to front,
A1 132 VDC K1 302.1 VDC A 131.1 VDC K 3.1 VDC CHECKED CATHODE K1: SIMILAR RESULT! Bill. |
21st May 2020, 10:00 pm | #57 |
PJL, I made another mistake in post #56: It was anode pin 6 that was high not cathode pin 3. I have a bit of a headache so will leave it for tonight, sorry. Clearly not supposed to be measuring voltages right now.
Thanks for your patience. Bill. |
21st May 2020, 10:04 pm | #58 |
No problem, you must have put a few hours in on this, have a break!
22nd May 2020, 1:14 pm | #59 |
Hi again, what should my next move be?
22nd May 2020, 1:35 pm | #60 |
Redo the voltage measurements?
