26th May 2018, 1:44 pm | #1 |
Tricity Vogue Fridge
Hi, can someone help to give me an approximate date of manufacture for my Tricity Vogue fridge. Thanks.
26th May 2018, 3:00 pm | #2 |
Re: Tricity Vogue Fridge
What colours are the wires in the mains lead?. Assumiing the lead is original, if they are red black and green, then it dates from before July 1970, If they are brown blue green/yellow, then it dates from 1970 onwards (or the lead has been replaced). If you have the instructions, there might be plug wiring instructions giving the colours it was sold with in there.
26th May 2018, 3:38 pm | #3 |
Can't edit my previous post, but I've just found this old advert on Ebay for Tricity Fridges from "c1964" https://www.ebay.it/itm/152888394369, which shows a Tricity Vogue that looks like yours. In view of this, I think its likely that the "265" in your serial number (3rd photo) is a date code for 1965
26th May 2018, 7:08 pm | #4 |
Oh wow, that's amazing to think it's still working after 50+ years. Thanks for your help.
Is there anything I can do to aid the longevity of such an appliance? |
26th May 2018, 7:32 pm | #5 |
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
That is a lovely looking fridge! Love the trim around the corners and edges. Does the compressor run quietly still?
Dom Less snakes...more ladders! Last edited by sexton_mallard; 26th May 2018 at 7:57 pm. |
26th May 2018, 7:47 pm | #6 |
Yes it's almost silent. Works very well and is immaculate inside still after all this time!
I |
26th May 2018, 7:59 pm | #7 |
To prolong its life: vacuum any dust off the rear 'radiator' every couple of weeks and defrost on the same schedule - this maintenance will give the compressor an easier life in its old-age.
Biggest 'killers' of fridges/freezers I've found are when the insulation in the carcase age-degrades and goes crumbly (meaning you then get the insulation taking-up condensation which leads to invasive rust in the outer shell) and similar age-related failure of the plastic inner shell - which can develop both major structural cracks and much finer surface-crazing - this latter providing a great place for bacteria/moulds to become established which then becomes a bit of a health-hazard. |
26th May 2018, 11:53 pm | #8 |
I'm still using the Prestcold fridge my parents gave me. It was bought in 1964 and has been in use ever since. Apart from its mains flex having to be replaced, I've not had to do anything to it. Oh I did replace the internal light with an LED one. Not because it failed, just because the LED is brighter and doesn't produce much heat.
27th May 2018, 12:19 am | #9 |
That is a very attractive fridge. The styling certainly looks mid 60s.
The three things that often fail on old fridges are the compressor motor itself, the thermostat and the door seals. The most likely fault is bad seals - if they are leaking, the freezer compartment will ice up badly after a month or two. |
28th May 2018, 3:44 am | #10 |
Many of our older fridges were damaged BER by a person trying to remove an ice buildup in the freezer compartment by using a ice pick or a screw driver to remove the buildup. The walls in the evaporator are thin and damaged very easily and letting the refrigerant escape.
28th May 2018, 5:47 pm | #11 |
Yes, its easy to damage the evaporator of a fridge. That is particularly true of a "modern" one that has an aluminium evaporator. My vintage Prestcold has a copper one that has been coated/plated with something that looks silvery.
An all copper system avoids the scourge of modern fridges which is the pressed aluminium to copper seal. That is the most likely cause of slow loss of refrigerant. The copper/aluminium joint is subject also to electrolytic corrosion. Often the joint is painted or coated to reduce that effect. Last edited by space_charged; 28th May 2018 at 5:59 pm. |
28th May 2018, 9:54 pm | #12 |
I use an old cylinder vac on "blow" to rapidly defrost fridges and freezers. It is also very effective in getting them bone dry once all the ice has gone.
29th May 2018, 1:24 am | #13 |
I have always used a large SLA battery and a large processor fan to clear ice.
It is much quieter than a cleaner on blow. |
29th May 2018, 10:01 am | #14 |
A bowl of hot water was my defrosting favourite, before we got frost free stuff.
29th May 2018, 12:03 pm | #15 |
Thanks for all the advice, and the help in dating this appliance.
I picked this fridge up last week off Facebook Marketplace and paid £15. Bit of a gamble as the working condition was unknown, but the fridge has been in operation almost a week now and appears to be Ok. Fingers crossed(!) |
29th May 2018, 3:12 pm | #16 |
I always use this method. I just put two metal pans filled with hot water in the freezing compartment. Its ready to go again in a couple of hours. I always give the insides a good clean and a quick spray with 0.1% BAK.
