Old 27th Apr 2018, 5:50 pm   #1
k_yller
Default 6 watt push-pull amplifier
Preamp and splitter on EF95, triode strapped. Output stage EL95, fixed bias. Case MDF with zebrano veneer.
ID:	161902   Click image for larger version
ID:	161903   Click image for larger version
k_yller is offline
Old 27th Apr 2018, 5:59 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: 6 watt push-pull amplifier
I like the style and precision of your tagstrip-wiring: I've done a few designs that way myself.
G6Tanuki is offline
Old 27th Apr 2018, 6:08 pm   #3
IanBland
I agree, that's a very handsome example of construction there. Both inside and out!
IanBland is offline
Old 27th Apr 2018, 6:34 pm   #4
Al (astral highway)
Al (astral highway)'s Avatar
Nice workmanship indeed, bravo!
Al
Old 27th Apr 2018, 7:29 pm   #5
Steve_Bell
It looks really elegant. Did you use a published circuit design? I've been meaning to get round to building an EL95 push-pull amp for over a year now.
Steve_Bell is offline
Old 29th Apr 2018, 9:03 pm   #6
k_yller
Thanks all for appreciation
Originally Posted by Steve_Bell View Post
/../Did you use a published circuit design? /.../
Circuit of my own design . I have to make few tweeks before I will be able to publish it.
Telefunken Magnetophone85 has very good design of EL95 PP amplifier.
k_yller is offline
Old 29th Apr 2018, 11:39 pm   #7
Argus25
No Longer a Member
Very tidy and well thought out layout.
It is always worth the extra work and time required to plan and make a project well and have it look beautiful when it is finished, then you can be very proud of it, which you should be, well done.
Argus25 is offline
Old 19th May 2018, 7:24 pm   #8
qualityten
It would be interesting to see the circuit, with information about the transformers and their covers. Beautiful work.
qualityten is offline
Old 19th May 2018, 9:03 pm   #9
k_yller
Hi
transformers - from tbt-trafobau, bought on german ebay
hint-ausgangubertrager.
covers -it was stainless steel kitchen containers
circuit-before 0.47uF cap is 50k potentiometer, triode strapped EF95 ,( enough for input from CD ) can be also connected as pentode but in this case you have to remember some of EF95 are very microphonic, in feedback loop is 20k resistor,
fixed bias from PSU on LM317 then potentiometers, capacitors in anode circuit (1500pF) depend on transformer build , from 1nF to 2,2 nF
Heaters are biased on +70V (Vch 90V)
k_yller is offline
Old 20th May 2018, 8:23 am   #10
qualityten
Thank you for sharing.
Old 20th May 2018, 11:53 am   #11
Peter.N.
Very nice, that's proper electronic equipment. Everything I repaired my first few years in the trade was built like that.
Peter
Peter.N. is offline
