14th Sep 2017, 2:57 pm | #1 |
What would happen if I made an MW pantry TX aerial like this ?
Basically , for use around 1.5MHz, an antenna made of say 4 metres of coax but with the Earth braid outer swapped ... outer braid to the load and the core as ground , then the termination connected with a 50R resistor.
Al |
14th Sep 2017, 3:42 pm | #2 |
Re: What would happen if I made an MW pantry TX aerial like this ?
It would radiate a weeny bit, most of the power would be dissipated in the 50 ohm resistor.
14th Sep 2017, 8:59 pm | #3 |
Hi Al, and you might get a lobe from your 50R depending on its type and if screened.
Ed |
