20th Feb 2008, 3:47 pm | #1 |
Hacker Mayflower RV14 - help needed
I've got a RV14 without any drive cord or station pointer . Has anybody got a diagram of the cord layout and/or a picture of the station pointer, so I can try to make something similar? I also can't figure out how the back panel attaches to the cabinet Thanks David |
20th Feb 2008, 4:17 pm | #2 |
Re: Hacker Mayflower RV14 - help needed
Ah, you bought that one from ebay then Dave!
I think I've got the service manual at somewhere at home which you are welcome to borrow. |
20th Feb 2008, 4:56 pm | #3 |
I'll try to take a photo of the cord & pointer on my set for you later today, unless someone else beats me to it. From memory, I don't think the manual includes a diagram, although there might be a written description of the layout.
The back cover is held on by sliding catches (four of them, I think) which should remain attached to the slots in the back cover. These engage with the thin wooden strips on the inside surface of the cabinet. Roy |
20th Feb 2008, 5:15 pm | #4 | ||
All I need now is some photos of the pointer, even ones just showing the pointer behind the tuning dial would be helpful. Quote:
Thanks David |
20th Feb 2008, 8:07 pm | #5 |
Hi David,
I have about 20 pics on my PC from when I re-strung my RV20. Most are rather good, but the only one that shows the cursor/ponter is this less than perfect one... If you'd like the others, just send me a PM with your e-mail address. Cheers, Nick. |
20th Feb 2008, 8:15 pm | #6 |
As promised, some photos of the pointer and back cover catches.
The pointer should be easy enough to fabricate, and that type of carrier is used on many sets, so someone may recognise it and be able to supply one. Those back cover catches are also commonly used. I'm sure I have seen them on Cossor sets as well. Be careful when you replace the chassis in the cabinet, as it is easy to knock the sharp edge of the scale backplate against the painted scale and damage it. A piece of tape over the end nearest the magic eye will offer some protection. Good luck, Roy |
21st Feb 2008, 1:36 am | #7 | |
Yep, that's the one, I think I got it at a bargain price too!
Nick and Roy, Thank you very much for the excellent pictures. I'm sure I, now, have all the information I need. Quote:
Thanks David |
