Old 19th Mar 2019, 6:28 am   #1
dmaillard
dmaillard's Avatar
Default Akai X-330D Remote Control Plug
I have an Akai X-330D that has the remote dummy plug missing. Does anyone know which pins are required to be shorted to enable the transport mechanism to operate.
Thanks
dmaillard is offline
Old 20th Mar 2019, 2:40 pm   #2
TIMTAPE
Default Re: Akai X-330D Remote Control Plug
HiFi Engine has the service manual and the owner's manual for this model. You might find the information by reading one or both. You just need to register.
I have here an Akai 280 with a remote dummy plug but not sure if it's the same as your model.
Tim
TIMTAPE is offline
Old 21st Mar 2019, 4:32 am   #3
dmaillard
dmaillard's Avatar
Hi Tim,
I already have both the service & the owners manual for this machine, downloaded from Hifi Engine. Unfortunately no info on the dummy plug in either manual, & the schematics aren't clear on where the links should go. Also other Akai models have different wiring on their remote socket, so there doesn't seem to be a standard. I believe Akai GX-280(D/D-SS), GX-285, X-360D, GX-365D and GX-370D machines have pins 1-11 & 5-6 shorted so I'll check their service manuals & see if I can use that info to work out the corresponding pins on the X-330D that require shorting.
Regards
Old 21st Mar 2019, 5:37 am   #4
radiotechnician
In the Akai Schematic Diagram Register 084, the schematic diagram 13818544
for sys con 10R 139A 2ed , Mecha & Power Supply shows Remote Socket 0601
but pin 11 is not connected.
The schem. for the 280 D shows pin 11 earthed.
Examination of photos in the instruction manual figs. 8, 9, 11 and 56,
showing the remote control being attached do not show the dummy
plug, nor is removal mentioned.
Perhaps on that model there is no need for the dummy plug.
Now I'll dream about those ( redacted) machines from long ago.
Steve Dow
VE7ASO
radiotechnician is offline
Old 21st Mar 2019, 8:14 am   #5
dmaillard
dmaillard's Avatar
The user manual (page 30) for the X-330D states that the dummy plug must be inserted if the remote control is not connected.
I’ve been trying to make sense of the schematic with respect to the remote control socket but it is quite different to other Akai models.
Old 21st Mar 2019, 10:27 pm   #6
radiotechnician
I am looking at the schematic presently too. You must have a different
operators book. Below are what is in the one from Hi Hi Fi engine.
I have three Akai beasts in the room right here. One is an Akai 365-D
Rather dusty. And hope it says that way.
Name:	X-330  Operators manual.jpg
ID:	180309   Click image for larger version
Name:	X-330 remote control.jpg
Steve Dow
VE7ASO
Old 22nd Mar 2019, 12:24 am   #7
dmaillard
dmaillard's Avatar
Hi Steve,
The user manual for the X-330D, (downloaded from Hifi Engine), is slightly different to the X-330, as can be seen from the attachments.
Regards
ID:	180314   Click image for larger version
Old 22nd Mar 2019, 4:07 am   #8
Restoration73
Restoration73's Avatar
Akai models with a "D" suffix do not have built-in speaker amplifiers, i.e. line out only.
Restoration73 is offline
