9th Jun 2015, 4:11 pm | #1 |
Creating a fault for demonstration purposes
Recently when I was assembling a lamp limiter my youngest son expressed some interest in how it worked and so I gave him a brief explanation. A verbal explanation has it limitations though and doesn't illustrate well so I told him I would also demonstrate how it works at a later date when I unearth one of the receivers currently buried in the garage.
I know this receiver works and I should therefore get the 'dim bulb' scenario to demonstrate, but I am trying to think of an easy fault to create first which will illustrate the 'bright bulb' scenario which we can then track down and correct together before demonstrating the dim bulb fix. Any ideas? The receiver is my McMichael 808AC superhet. Thanks Nick |
9th Jun 2015, 4:29 pm | #2 |
Re: Creating a fault for demonstration purposes
You need a fault which won't wreck anything or be dangerous. A short on the HT line might be a bit too risky.
A dead short on the mains would fit the bill, albeit a bit unrealistic, though something like a stray strand of wire across the mains switch terminals (assuming it's double pole) would suffice. N. |
9th Jun 2015, 5:44 pm | #3 |
Add a leaky mains suppression capacitor? Then you can watch it fizz, smoke and pop while the lamp flickers and brightens.
9th Jun 2015, 8:29 pm | #4 |
A short on the heater winding of the mains transformer? Should increase the current enough to cause the lamp to light up.
Keith |
11th Jun 2015, 4:58 pm | #5 |
Thank you for the suggestions.
I would like to try the leaky mains suppression cap and also the short on the heater winding. Could both of you provide me with a detailed explanation of how I achieve both? Sorry to be a pain, but I don't have enough experience to know how to do it without some guidance. Many thanks Nick |
11th Jun 2015, 5:55 pm | #6 |
The 808 is not an easy set to use but the short on the heater winding is easy to simulate. Remove one of the valves (not rectifier). Link the heater pins by wrapping wire round them near the base . Replace the valve, the frequency changer is probably the easiest to use.
This will simulate a genuine fault without having to disturb any components or wiring. The fault might also be "found" by noticing that the valve heaters did not glow. This was used in the past by some instructors in the services teaching fault finding. |
11th Jun 2015, 7:50 pm | #7 |
John, that's perfect and easy too!
Thanks very much. I think that's all I'll need actually Many thanks Nick |
11th Jun 2015, 8:21 pm | #8 |
For a leaky HT smoothing cap you could put a resistor across the cap. Fairly easy and reversible.
Malcolm |
11th Jun 2015, 9:52 pm | #9 |
Ah! That simple eh Malcolm?
OK. I'll have a go at that too Thanks Nick |
12th Jun 2015, 7:22 am | #10 |
Possibly. I haven't done it myself. Let me know the result.
Malcolm |
12th Jun 2015, 7:48 am | #11 |
Don't forget that the resistor will dissipate a lot of heat. A 4.7k resistor across the cap would need to be rated at a minimum of 15W and a 1k resistor at over 60W (that would almost certainly light up the lamp limiter).
Keith |
12th Jun 2015, 6:12 pm | #12 |
Thank you Keith, I shall bear that in mind.
Nick |
12th Jun 2015, 9:35 pm | #13 |
That's why leaky smother caps get hot. A lot of power is dissipated in a sealed can.
Malcolm |
13th Jun 2015, 10:30 am | #14 |
The heater short is also perhaps the safest one for lighting the limiter. Only the transformer is overloaded and it has the benefit of a fair bit of thermal inertia before anything irreversible happens. Leaky suppressor caps if genuine tend to go bang and to simulate (other than with a direct short) could be hairy. Also, plugging direct into the mains with the heater short would also be short term survivable
13th Jun 2015, 10:40 am | #15 |
I've never tried the heater short as I don't use a lamp limiter but it sounds a safer option, plonking stuff across the HT line could damage the rectifier.
At least the heater winding is usually made of sterner stuff than the HT winding and should dissipate heat quicker. If it's just for a demo then perhaps an outboard arrangement with two switchable resistive loads and a multimeter to show wot's wot. Good luck whicheverways. Lawrence. |
