Old 25th Mar 2019, 8:32 pm   #1
Barraman
Default Cleaning aluminium
I've got a Cushcraft multi-band vertical which I'd like to dismantle and clean up.
It's aluminium in several sections, plus traps. The outside of each section is
easy enough to rub down, but the insides are not so simple, especially the
smaller diameters. Each section overlaps about 3'' and it was suggested to
stand the sections in a rhubarb solution (oxalic acid?). But there must be a
better way? Any suggestions appreciated, thank you.
Richard
Barraman is offline
Old 25th Mar 2019, 9:38 pm   #2
Default Re: Cleaning aluminium
No need to clean all the way through the overlap, this is for strength, a quick rub with emery paper at the very end for electrical contact will do. And do smear Vaseline on the joint too.
Old 26th Mar 2019, 7:20 am   #3
Barraman
Yes, you're right, 3'' is a bit much. But I would like a good inch of clean metal
on each section to ensure a good electrical contact. The small diameter sections
at the top of the aerial are fiddly to clean, and I just wondered if the rhubarb
trick would work? I'll have plenty of it come the summer!
Barraman is offline
