27th Nov 2018, 5:32 pm | #1 |
Hot mains transformer
This transformer has a nominal 230-v. primary and a tapped secondary: 0v. - 12v. - 24v. So a total N/L voltage of 36v. It's of a conventional construction: E and I laminations, pri. & sec. wound on it. Physically, it is about 3½ x 2" x 2½". I think it might have come from a Fidelity UA6 music centre.
With a resistive load on the sec'y., a 3-amp. draw caused the sec. voltage to drop from 36v. to 34v. I ran that test for 1 minute. However, prior to serious use, I put it on a 'soak test' with no load. After about 30 minutes, I touched to top of the laminations clamp: Yow! That is really hot: two seconds of finger contact was enough! Intrigued, I made a few measurements: Pri. resistance: 15 Ω; pri. inductance: 800 mH; no-load current about 1 amp. From that, it seems to me that it is the iron loss that is the main contributory factor to that heat. (So N/L power factor approaching unity ). So, as far as I'm concerned, this transformer is not suitable for use. However, is there a fault in the pri. winding? (To me, seems unlikely) or is this simply a case of poor design? (To me, seems most likely). Al. |
27th Nov 2018, 5:43 pm | #2 |
Re: Hot mains transformer
Shorted turns?
27th Nov 2018, 5:45 pm | #3 |
How do you get 36 volts from a 24 volt secondary?
Lawrence. |
27th Nov 2018, 7:04 pm | #4 |
maybe its a typo and he means its 12-0-24 V?
Which strikes me as a bit odd. rather than 0-12-24 I wonder if it should be a 12-0-12 CT job? which means it would be capable of 24V end to end on the primary (You can;t wire it in series it's already in one piece.) or 12V if FW rectified (at full load). I am sure Al will elucidate. I'm suspecting a shorted turn on one side of the centre tap and maybe its really 24-0-24V, the short being around halfway down one side? Andy. |
27th Nov 2018, 7:14 pm | #5 |
ms660: The secondary is not 24-v.
The secondary winding has a tap, so there are 3 connections from that secondary. Calling one end of the whole winding 0v., relative to that, the tap is 12v. Relative to that same 0v. end, the other end of the winding is 36v. So the voltage between the tap ('12v.') and at the end of the winding ('36v.') is 36v. minus 12v. = 24v. Yes, I should have explained things clearer in my O.P. (It was written amongst doing 3 other jobs - all urgent! ) My apologies to all those here who were confused. Al. Last edited by Skywave; 27th Nov 2018 at 7:25 pm. |
27th Nov 2018, 7:24 pm | #6 | |
To me, at the moment, s/c turns on the pri. seems the most likely cause, especially since the wire on the pri. will be much thinner than that on the sec. Al. |
27th Nov 2018, 7:28 pm | #7 |
So 0v-12v-36v, not 0v-12v-24v as was originally stated, it might be the 3 amp current draw that's damaged it?
Lawrence. |
27th Nov 2018, 8:07 pm | #8 |
Yes, 0v-12v-36v. As I wrote, sorry about the confusion and my poorly written OP.
Possible cause: excessive current draw on the sec. which has damaged it . . . well, yes, maybe. I can see that the wire on the sec. is quite thick. Perhaps I'll run some voltage regulation tests of the secondary; might be informative. Al. |
27th Nov 2018, 8:35 pm | #9 |
It does sound rather hot, there's a lot of iron losses there!
If there's a shorted turn, I'd expect there to be an obvious hot-spot, and 30 minutes would make it smoke. You don't have that. Sometimes, transformers for intermittent use may be operated at a very high flux density, so core losses are high. This allows fewer turns, of thicker wire, to be used, so resistances are less and regulation is better - and you can suck more power from a smaller sized unit. However, if it really came from a music centre, that won't be the case. So knowing the original use would be really helpful! |
27th Nov 2018, 9:34 pm | #10 |
Could it be that the lack of a secondary load means the transformer is saturating, so losing inductance and consuming lots of magnetising current - which then heats up the primary copper. It is quite common for cheaper transformers to be run quite near saturation, especially when off load. Also, the transformer will have been designed to power a device; surviving not powering the device may not have been in the spec.
27th Nov 2018, 11:25 pm | #11 | |
No Longer a Member
I think the core has in some way deteriorated. The core's losses are Eddy current and Hysteresis losses. If we postulate that the magnetic properties of the core have not changed from new, then perhaps the Eddy current losses have skyrocketed due to the laminations connecting themselves together over time. Clean some of the lamination edges about 1cm apart and check for continuity with the meter. |
28th Nov 2018, 12:27 am | #12 |
Perhaps I should have stated this earlier. This xfmr. has the following printed on the winding protective covering. T3573 DE Ltd.
A Google search yielded nothing. Al. |
28th Nov 2018, 9:30 am | #13 |
Being too hot to touch is not necessarily a fault, some are intended to do that, simply because there is less iron, so they are cheaper and lighter. A cheap music centre will be engineered for minimum cost of manufacture, with little concern for cost of operating it, so the transformer may well be cheap and lossy
28th Nov 2018, 10:00 am | #14 | ||
As above, total losses unloaded can never be more than total losses when loaded (stated without proof - feel free to challenge me on that till I prove it!). All that happens as you ramp up the load from zero is that core losses may drop (as above), while copper losses rise. But rise of copper losses is always greater than fall in core losses. |
28th Nov 2018, 10:46 am | #15 |
It's the 3 amp current draw through a resistor load that concerned me, that's a lotta watts for the resistor and the transformer, 102 watts so far as I can make out.
Lawrence. |
28th Nov 2018, 11:24 am | #16 |
Dimensions of a modern 100VA transformer available from RS: 89 x 68 x 75mm
Approx dimensions of this transformer, converted to metric: 89 x 51 x 63mm So it's probably not 100VA, and 3A would have been asking a bit much. Although it shouldn't have damaged it in the space of a minute. The no-load primary current draw of 1 amp is the real indicator here - most likely a shorted turn, as suggested earlier. But a quick test on a variac might help to establish if the problem is with the core. I can't find any data on-line about the Fidelity UA6, but I really doubt it would have been fitted with a 100VA transformer. Any idea what the power output would have been? Even if it was 50 watts per channel - which would have been a lot of power for even an upmarket Fidelity - the peak-to-mean ratio (or crest factor) of music means that you can seriously cut corners with transformer ratings, and I'm sure Fidelity would have taken full advantage of that. Either way, given that class B amplifiers don't draw much current when idle (and don't draw all that much more on average when playing music), I seriously doubt this transformer was designed to require a significant load. Having rescued way more transformers from audio gear than I have room for, I'd expect the no-load draw from the mains to be a few 10s of milliamps at most. |
28th Nov 2018, 12:20 pm | #17 |
Do you have a variac so that you could repeat your no-load temp expt - but with the voltage to the transformer reduced to 220 volts say? This is just in case the transformer was designed for what was the typical European mains voltage.
28th Nov 2018, 12:42 pm | #18 | |
No Longer a Member
Tm = V/(4.44fNm^2) where m^2 is the core cross sectional area and N the number of turns. For power transformers like this, that are struggling with high flux densities that push the core into the saturation region, lowering the applied voltage (or increasing the frequency say from 50 to 60Hz) will help. So if the transformer was intended for 220V the problem will obviously be worse on 230 to 240V. As I mentioned the ones I have had trouble with in this respect were intended for 60Hz and running them on 50Hz is quite problematic. One way to examine if the core is being pushed into heavy saturation in the cycle, is to place a 1 Ohm current sense resistor in series with the primary. I have a scope with totally isolated inputs to examine the voltage developed across the resistor , a Tek 222PS, but in this absence of that isolated scope, feed the transformer primary by an isolating transformer and earth the primary connection that has the 1 Ohm resistor, so as to measure the voltage across the resistor with a standard scope. The current is not a sine wave, it has a characteristic shape relating to the core properties. Last edited by Argus25; 28th Nov 2018 at 12:50 pm. Reason: typo |
28th Nov 2018, 12:44 pm | #19 | |
Scoping the current will tell if the core is saturating or if there is resistance loading. |
28th Nov 2018, 1:28 pm | #20 | |
Good advice from Hugo! Another way, which might be simpler still - use a Variac to power the transformer and measure the current at 50V, 100V, 150V, 200V, 250V. Plot a graph. If there's a shorted turn, the current will be proportional to voltage, more or less (assuming there's no arcing going on in there). If it's just a saturation issue, current will be low at lower voltages and then ramp up disproportionally at higher |
