15th Oct 2019, 12:40 pm | #21 |
Re: Here's an unusual creature. TV with 8 track player.
Here's LA-based youtuber shango066 loading a Curtis-Mathes all-in-one entertainment `center` onto his pickup.
It contains a Garrard record deck. https://www.youtube.com/watch?v=D9QvwUGWyoM
Kevin |
15th Oct 2019, 1:21 pm | #22 | |
Wouldn't fancy lugging one of those out a skip
Regards, Ben. |
15th Oct 2019, 9:54 pm | #23 |
Hello, sorry when I said twin panel I meant the set had two vertical pcb's, IF on the left and timebases on the right. Valve UHF tuner although I seem to remember later types had a transistorised one, long before the integrated 6 button one.
16th Oct 2019, 11:27 pm | #24 |
Could it be a Sears Cartrivision system? An early video recorder using 12.7mm. tape on stacked spools.
As well as the obvious self-recordability, there was the option to rent pre-recorded feature films by post -- the films coming on special cassettes that had no drive to the supply spool, so you only got to watch the movie once! A special rewinding machine would be used in the rental shop.
17th Oct 2019, 12:23 pm | #25 | |
Lee |
17th Oct 2019, 5:45 pm | #26 |
Here is a YouTube video of an 8track Greek Radiant TV from the 70s according to the description.
https://www.youtube.com/watch?v=nL3v4MMDAK8 Owner demonstrates the 8 track. |
