Old 21st Jul 2019, 11:36 am   #1
Hammonds
Hammonds's Avatar
Default "Punch down tool ?" identification, please
Good morning, All
I was having a clearout and came across this tool, which looks like some sort of punch down device.
As you press the tool down, a spring loaded brass tube comes down between the two "wings".
If anyone can identify it I would be grateful and would be happy to give it a new home FOC.
Dave
ID:	187053   Click image for larger version
ID:	187054   Click image for larger version
Hammonds is offline
Old 21st Jul 2019, 12:09 pm   #2
beamcurrent
beamcurrent's Avatar
Default Re: "Punch down tool ?" identification, please
Hi Dave
I think it's a "pin extractor" tool that you would use on a large and probably very expensive connector.
These pins were crimped on to the wire and then inserted into the connector body, latching in with a "barb" arrangement. The extract tool compressed/released the barb enabling the pin to be removed.
As to which type of connector it fits, a bit tricky!!
Regards Brian
Visit the Virtual Broadcast TV Camera Museum
beamcurrent is offline
Old 21st Jul 2019, 1:01 pm   #3
barrymagrec
Certainly looks like a pin extractor, difficult to gauge the size from the pics but it could be for the large high current pins used in some D shells - 13W3, for instance.
barrymagrec is offline
Old 21st Jul 2019, 2:02 pm   #4
Radio Wrangler
Radio Wrangler's Avatar
Could also be for any of several families of round connectors.
You'll need to get a micrometer on the OD of the business end and maybe try different sized drill shanks to gauge the ID. Only with these numbers to start with will anyone be able to decide if it's a possible fit.
Radio Wrangler is offline
Old 22nd Jul 2019, 5:56 pm   #5
duncanlowe
I'd go with pin extractor too. I have several similar devices for automotive connectors including one that looks very similar though three slots. I had it for almost fifteen years before I found which connector on the car it was for.
The slot is unusual, and on my three slot version is to fit around some support 'fins' and get down as far as the barbs that have already been described.
duncanlowe is offline
