Old 10th Apr 2019, 8:12 pm   #41
Simon Gittins
Default Re: Ferguson 382U Firefly not playing ball
Not the cause of radio silence but have you used a Class X capacitor for that orange one in the 1st picture going from switched live to chassis? If the replacement isn't rated for use across the mains it could go bang!
You could just leave it out whilst testing. The capacitors to the sockets should be Class Y but again they don't need changing until you have the set working.
Simon Gittins is offline
Old 10th Apr 2019, 8:53 pm   #42
PJL
Unfortunately, the pictures are still too difficult to follow, not helped by you leaving the old parts in place and snipping one end!
You should be using capacitors that are rated for at least 250V and preferably 400V. I am not sure about the disc ceramics you have used but there seem to be some grey sleeved ones and I remember those being 63V?
I suspect the original image files you are using are better resolution and detail is being lost by the attachment. Maybe you could PM me the originals?
Peter
PJL is offline
Old 11th Apr 2019, 8:53 am   #43
el gringo
Hi Simon/Peter,
Thanks for looking, just checked and both of the orange ones are > 250V rated and the grey ones are apparently marked "500v.
( happy to send images min PMs, dies anyone know how to do this? )
Pete
el gringo is offline
Old 11th Apr 2019, 9:58 am   #44
Station X
Station X's Avatar
Images cannot be attached to PM's. You'll need to use email.
Graham. Forum Moderator
Station X is offline
Old 11th Apr 2019, 10:08 am   #45
jonnybear
jonnybear's Avatar
Hi Pete
The voltage marked on the capacitors ie 250v is a DC rating, If a capacitor is used in AC circuit or across the OP transformer this voltage needs to be trebled at lest, to be on the safe side.
John
jonnybear is offline
Old 11th Apr 2019, 10:21 am   #46
Simon Gittins
If the capacitor I mentioned in post 41 is rated at 250V DC then it's not suitable for use across the mains.
General information on capacitor replacement:
https://www.vintage-radio.net/forum/...ad.php?t=18962
Information on Class X and Class Y capacitors:
https://vintage-radio.net/forum/showthread.php?t=56159
I wonder whether the DSO that you have could be used to pin down the fault to a particular stage. I'm not familiar with DSOs but if you post details of the one you have someone may be able to advise.
Re the pictures; four overlapping ones of the chassis may give better results.
Old 11th Apr 2019, 10:39 am   #47
ms660
ms660's Avatar
I would replace with a suitable type or remove the replacement mains bypass capacitor shown in the photo PDQ before it explodes, I would also replace the Hunts 0.02uF that's shown in the photo, it's the coupling capacitor to the audio amplifier, they are prone to going electrically leaky, if it goes leaky the bias voltage on the grid can be seriously reduced, that can lead to increased distortion.
Lawrence
ms660 is offline
Old 11th Apr 2019, 10:43 am   #48
Herald1360
Herald1360's Avatar
Which could be the least of the problems it causes!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 11th Apr 2019, 10:45 am   #49
el gringo
Ah okay point taken re cap DC voltage rating!
Very interesting posts on X and Y rated capacitors! Looks like I'm gonna be replacing those for sure..
Will attach four overlapping pics too..
Old 11th Apr 2019, 10:50 am   #50
ms660
ms660's Avatar
I don't get that....
Lawrence.
ms660 is offline
Old 11th Apr 2019, 10:59 am   #51
Nuvistor
Nuvistor's Avatar
I took it to mean that the increased Ia through the valve could damage the valve, output TX etc.
Frank
Nuvistor is offline
Old 11th Apr 2019, 11:22 am   #52
el gringo
5 overlapping images ( they seem to be fairly heavily reduced! )
Pete
ID:	181201   Click image for larger version
ID:	181202   Click image for larger version
ID:	181203   Click image for larger version
ID:	181204   Click image for larger version
Old 11th Apr 2019, 11:28 am   #53
ms660
ms660's Avatar
If that's what he was meaning (we don't know for sure yet) he would be wrong.
Lawrence.
ms660 is offline
Old 11th Apr 2019, 11:51 am   #54
Nuvistor
Nuvistor's Avatar
Hi Lawrence,
Just checked the photos and circuit, is the 0.02 you refer to connected between the triode grid and V/C C51 on the maker's circuit?
Frank
Nuvistor is offline
Old 11th Apr 2019, 11:52 am   #55
ms660
ms660's Avatar
It was indeed, that's the fella (the capacitor).
Lawrence.
ms660 is offline
Old 11th Apr 2019, 2:16 pm   #56
PJL
I can see C22 (0.005) that is the grey sleeved small capacitor. Are you sure this is 250V or higher?
Where is C21 (0.005)? It seems to be missing.
PJL is offline
Old 11th Apr 2019, 2:44 pm   #57
PJL
And C47 hidden in the waveband switch is a Hunts and will need replacing. This is only used for FM so ignore this for now, just work with MW.
PJL is offline
Old 11th Apr 2019, 3:10 pm   #58
el gringo
Thanks PJL - was about to ask about C47 too ( just seen it lurking between the two wafers ) I'm not at all sure about the AC rating for that small grey cap? it's printed value appears to be "500v". For C21, I've got a longish thin red cap going from pin 1 of V2 to ground, is that it?
Thanks Jonny - I really only ever worked on low voltage stuff when I was an Engineer, so this is def kinda new to me!
Pete
Old 11th Apr 2019, 3:27 pm   #59
PJL
OK, so C21 is an original ceramic capacitor? Should be OK although they do sometimes break in two if you move them about too much. It is not possible to see Pin 1 in your picture so can you confirm both C21 and C22 (critical for RF) are connected to pin 1.
Just to be sure we are on the same page, we are working off trader 1299.
PJL is offline
Old 11th Apr 2019, 3:43 pm   #60
el gringo
Hi yes it is the original. Both C21 and C22 ( the replacement grey one ) are connected to pin 1 of V2.
Pete
